XM signal dropping out? - NewBeetle.org Forums
Old 07-11-2006, 04:27 AM
skittles's Avatar
Default XM signal dropping out?
I activated my XM radio trial today on my NBC and loved all the variety. However, I didn't love the fact that the signal kept dropping out on me. It did it over 15 times - mostly on roads where there were lots of trees.
Is this normal? I checked the XM website to see if there was an FAQ on it and nothing.
Old 07-11-2006, 06:08 AM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Default Trial vs Signal
Is it possible that the trial period has a weaker reception signal. Either that or satelites are dropping out of the sky.
SoCalnewbeetleclub
Old 07-11-2006, 11:55 AM
hestersu's Avatar
Canyon, TX, USA
The signal is the signal regardless of trial period or not. I've noticed that if I am on a road with heavy canopy or anything substantial to the south of me, I will lose signal. I have 3 XM units and this happens on all of them. Annoying but not a problem. It has to do with the position of the satelites relative to our position.
I believe this is a common issue regardless of the service one might use.
Susan Hester
Former owner of:
Old 07-11-2006, 01:49 PM
MedfordBumbleBee's Avatar
MedfordBumbleBee
Medford, OR, USA
Car: 2001 New Beetle GLS 1.8 Turbo
What you are experiencing is typical with sat radio. Seems like every bank drive thru blocks my southern exposure so I always have no XM in a bank drive thru! XM does a better job in larger cities as they use landbased repeaters in larger cities. I love driving to Portland with my XM as it works almost everywhere there, under bridges, in tunnels, etc. In Medford, a big tree, my garage, etc. block the signal.
In my opinion, a little drop out here and there is still worth it for not having to listen to commecials!
Ed
MedfordBumbleBee
Look for the smiling NB on the roads of Oregon.
Old 07-12-2006, 07:03 PM
Wheaton, IL,
Car: 04 TDI PD
I get the same with my Sirius. Any thick tree canopies and I get a drop of signal.
Old 07-13-2006, 01:29 AM
larryziegler's Avatar
Clovis, CA, USA
Car: Ex 1999 Beetle GLS Owner/2005 Honda Pilot/2008 Acura TSX
Ditto on the tree issue with XM. I get it as well. I have my antenna placed on the dash where the windshield meets the dash, thinking the interior placement might add to the reception issues....I guess not. I am not about to re-route the antenna to the roof anyway, but this validates that the issue is with outside variables rather than my installation. Some of the more expensive satellite receivers do have a memory to handle short interruptions like this, I believe, thus making the assumption that there is never a reception problem....however that works.
hazard/turn signal flasher kneeskrapr Questions, Issues, Concerns, or Problems with the New Beetle 6 12-05-2010 01:19 PM
turbo-s front turn signal ? uf_gators Technical Modifications 4 07-14-2007 06:20 PM
Turn Signal Popped Out! Ted 2.5 Liter Gas 3 09-04-2006 04:57 PM
Need a turn signal lever XxchavoxX Market Place Archives 1 06-07-2006 07:13 PM
Turn Signal Issues 73ladybug Questions, Issues, Concerns, or Problems with the New Beetle 2 05-03-2006 02:16 PM
