Radio Removal Tools Question - NewBeetle.org Forums
Old 07-16-2006, 07:44 PM
Simpsonville, SC, SC, USA
Car: 2004 GLS
Default Radio Removal Tools Question
Hey,
My New Beetle already has a JVC unit installed, but I want to install my Alpine unit.
Do I need the radio tools to do this when the stock CD player is not there?
Thanks!
Tim Klein
Old 07-16-2006, 11:25 PM
bluebee's Avatar
Barack the vote!
Las Vegas, NV, USA
Car: 1998 Techno Blue NB 2.0L
We just put a JVC in my bug. I'm not sure what your set up looks like in your car, but for my own bug, in order to take out the radio you have to pry off the rounded VW face plate and then use these special things to take out the unit.
I still need to install the antenna connector for my radio, so I need to pull it out again. I can takes pics when I get the part so you can see if my set up is what you've got.
Bluebee & Donna
Old 07-16-2006, 11:36 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Default Stock vs. Aftermarket
Originally Posted by teklein
Hey,
Thanks!
Tim Klein
Removal keys are only needed to remove stock radios. The keys are inserted into small slots on each end of the radio. If the unit is an aftermarket install there shouldn't be any keys needed. Typically there is a face ring that clips around the head unit which, when removed, should reveal the rest of the radio bracket/bracing.
SoCalnewbeetleclub
Timing Belt Tensioner Removal Question GLXpress 1.8 Liter Turbo 1 06-12-2006 08:23 PM
XM, Ipod, Radio Question ktbug78 Car Audio 0 02-15-2006 01:04 PM
Looking For Radio Removal Tools MOONDOG316 Market Place Archives 10 02-11-2006 03:00 PM
Removal Tools MOONDOG316 Car Audio 1 01-10-2006 10:53 PM
A question about Satellite Radio / Television PhoenixRising Miscellaneous Hoo-Ha Archive 10 12-17-2005 05:19 PM
