You can replace anything you want in the bug, I'm not sure how easy it would be to replace the front speakers in the monsoon system, but the rears were simple. Once you get the side panel off, just unscrew, cut connector, hook up wires and screw in new speaker. In the monsoon system, the a-pillar has a screen over it to make it look like there's a little tweeter there, but there's not, the tweeter is next to the speaker in the dash. The speakers in the dash and in the rear should be 6-1/2" speakers as for tweeter I'm not sure on size, but you probably won't need it depending on what speakers you buy.
Check out my MySpace Say hello to "TS" Want something to give charactre to your bug, check this out |
In the monsoon there should be two rear 6-1/2", two front 6-1/2", two front tweeters, and two 8" subs in the doors I believe, don't quote me on the subs. My car was a non-monsoon, but othere than location of speakers and the amps everyting should be similar. I can't really tell you much about the monsoon though. As for rears making a difference i can't say, I haven't been in a monsoon car. I would PM SilverShadow and ask him about it. He has a nice soundsystem in his car. Here's a link to his thread SilverShadow
I had the monsoon system, till I changed almost everything stereo related. the rear's are 6.5" 2-ways and the fronts are 6.5" compoents with a 1" in the pillar and a 3" or 3.5" in the dash. I changed my rears to RF FanQ 6.5 comps and put the tweeter in the painted section up top with a custom cover to copy the tweeter pillar section. The fronts are RF FanQ 6.5 comps with a RF 3.5 mounted in the dash. So all my factory locations are being used adn then some.
Don't bother putting anything more than a 6 1/2" woofer in the doors as the monsoon amp only sends the lower freq's there. Of course, if you want to wire in a new amp, I'd say go for it.
The sound levels didn't change much when I replaced the rear speakers. It's still pretty quiet back there.
Science flies you to the moon...Religion flies you into buildings
While I have not yet changed the dash speakers, my opinion would be that they are probably going to be the easiest. To access them, if I remember correctly, you'll only need a torx tip screwdriver. The center panel closest to the windshield just slides forward, which reveals the torx screws of the side dash panels. Simple.
![]() Yeah, changing out the rears won't do much unless you add an amp to give them a bit more power. The stock Monsoon system is very front biased, and it sounds like you already figured that out. ![]() |
You went all out with your system I just want a lil better sound outta the head unit I have, Im just looking to do a speaker upgrade, I had a bose sysetem in my 2 previous cars, a Corvette and a Maxima and it was better than the monsoon system.
F.Y.I It is hot melted/tacked to the dash. You need to remove the wire harness to completely remove the dash panel (you'd likely figure that out right away). I'm still running a stock monsoon system less the HU so I'd be interested on the outcome ![]()
SoCalnewbeetleclub |
Joe (my husband) ripped out every single bit of the Monsoon from both our 2002 Passat (CD/Cassette) and my 2003 Turbo S (Cassette only). He left the pillar tweeters in place and transferred:
Kenwood Excelon CD/MP3 HU 2 sets of Infinity Kappa 6.5 speakers, front and back Kenwood 4 X 25 watt amp Infinity Basslink sub (self-contained amp) All my stuff came out of my 2004 GL. We left the grilles in place on the door panels and the backseat for a stock look (and from what Joe said, it was easier since the speakers had a lower profile than the Monsoon stuff). Now if Bose made aftermarket stuff, we'd be all over it!
2004 Galactic Blue GL, Cosmo (His pix are here.). Adopted 8/7/04, Readopted 8/10/06
2003 Reflex Silver Turbo S, Hermione! Adopted 7/4/06. Clicky For Pix! Oh, and by the way, I'm a virgin...again. |
| Tyrolsport Upgraded SMIC almost done! | NYBugman | 1.8 Liter Turbo | 2 | 07-31-2006 02:52 AM |
| do the headlight units come apart easily? | gilligan | Styling Modifications | 6 | 02-04-2006 03:31 PM |
| Not Bad (If you get offended easily [religious] please do not read) | AmyJane | Jokes | 4 | 12-16-2005 10:28 AM |
