If the sub is running off it's own amp, it's do-able, but you'll still have to run a power cable from the battery to the sub's amp, and ground it. But you could easily get speaker level and remote lead from the monsoon wiring harness.
There's a thread somewhere that has an pdf attacehd to it that has the wiring scematic of hte monsoon system on here. If i find it before you do, i'll post a link here.
In my old GTI with the monsoon I went with a high end Keenwood cause it was blue and red to match the dash. It was wired with the speaker level wires right into the amp. but here is the cool part. The head unit had a sub out with low pass and high pass crossovers for the speaker level outputs. This ment I could hook up a powerd sub and cross everything over so 80Hz so it sounded great and played like it had a 30-40 watt RMS amp on the high end but it was just a monsoon with more input power. The whole thing cost about $500 and I did it all myself. I used a single 10" kicker powerd sub box with 100 watt RMS amp built into the box. . The sound was great and it was alot louder then the stock monsoon and played real low without distorting..
2000 Reflex Yellow 1.8T GLX Mods, O2M 6 speed, EFI systrms DFI, GT30 Turbo, MBC, 62ibs Injectors, 3in Downpipe and Exhaust,custom water/air ic, ATP Exhaust Manfold, ATP Fuel Pump,Adjustable FP Reg, AutoTech steel flywheel W/Power Clutch, and HKs BOV, stroked to 2.0L, ported head W/shrick cams. 11,70@122..Dyno 409HP 370TQ @ 12PSI on 116 Octane. Other cars, 07 Tahoe LTZ and 06 620HP LS2 427ci GTO..FTI cam,AFR Heads,FAST Intake,Kooks Headers, and 175 NX Nitrous..9.73@142 on nitrous.. |
I just recently added a Alpine Deck and replaced all the speakers in our NB as well as added a JL Stealthbox.
I considered running the new speakers off the stock wiring of the Monsoon amp, however when I removed the stock speakers I noticed that they are labeled as 2ohm speakers. Because I was unsure if the amp is running at a 2ohm load I didn't want to ruin the new speakers (4ohm) by using the amp. Does anyone know anything about the output of the Monsoon amp or have any input on this? Output wattage? 2 or 4 ohm? The Memphis speakers don't need alot of power so the deck is ok but I wonder if they would sound any better with alittle more punch behind them. Intall Notes: '03 NB Turbo S Deck: Alpine 9856 w/Ipod Connection Doors: Memphis 6.5" Components w/Tweeters installed in the A pillars powered by the deck Rear: Memphis 6.5" Coaxial Set powered by the deck Spare Tire: JL Stealthbox Sub. AMP: JL 250/1 |
I LOVE IT!!!
It sounds like a million bucks, clear, crisp and will still pump out plenty of bass. If you want something better then this, you'll be looking at doing a full enclosure which is going to take up most if not all of your trunk space. For the someone that just wants some bass without loosing the trunk, this is a GREAT setup. If your an audiophile and you expect nothing but perfection and shake your neighbors houses think about having a High end professional system installed. |
| Which Subwoofer 2 choose ? | dkronie | Car Audio | 19 | 05-11-2009 04:51 AM |
| FS: JL Audio Stealth Box Subwoofer for New Beetle | w00sh! | Market Place Archives | 4 | 04-27-2006 05:09 PM |
| MTX subwoofer Question | degny21 | Car Audio | 1 | 01-13-2006 05:53 AM |
| How I can install Powered Subwoofer in New Beetle 2004 Convertible??? | s_santiago | Car Audio | 2 | 12-11-2005 06:19 PM |
| Subwoofer for Monsoon | Pappa_Bear | Car Audio | 2 | 11-14-2005 11:43 PM |
