Radio Functionality - NewBeetle.org Forums
Old 10-20-2006, 11:57 PM
Default Radio Functionality
Hi There,
I have had an aftermarket stereo in my 2003 beetle since immediately after I bought it a couple years ago. The face plate failed so I decided to reinstall the factory head unit.
The factory radio does not power on or off with the ignition but can be powered on and off via the power switch on the unit. The unit will also automatically turn off after an hour regardless of the ignition position.
Is the unit supposed to turn on and off with the ignition? I would think so but I didn't use the factory unit enough when I purchased the car to know. If this unit is not functioning correctly does anyone know what the problem is and has this issue been seen before?
Any information you could provide would be greatly appreciated.
Thanks,
Keenan
Old 10-21-2006, 02:55 AM
yelojkt's Avatar
beetle driver for life
Wichita, KS, USA
My unit stays on when you turn off the ignition but turns off when you remove the key. You can also turn it on with the key out of the ignition. it then stays on for awhile then shuts off.
Moded to make driver grin.
Did You see Yelojkt?
Dyno Video before custom K03S
09 ZX6R Candy Blue
AM Radio aefbug Car Audio 28 12-06-2006 06:50 AM
Factory Monsoon Radio and XM Radio GirlNextDoorTn Car Audio 1 12-15-2005 09:22 AM
anyone here like radio one - uk ? Mr Natural Miscellaneous Hoo-Ha Archive 1 12-03-2005 02:51 AM
XM Radio beetles2 Car Audio 1 09-25-2005 11:48 PM
