removal of radio - NewBeetle.org Forums
Old 11-08-2006, 04:45 PM
Default removal of radio
My head unit died in my 98 NB, and I checked the fuses on the door jamb, but I understand there are fuses located behind the radio/head unit. Is there a simple way to remove the dash or radio to check the fuse behind it?
Old 11-08-2006, 04:58 PM
QuanBlackBug's Avatar
totally wired beetle
Itasca, IL, USA
Car: '03 Beetle
there is a 10 amp blade style fuse behind the radio but you need special anti-theft radio removing tools which i have no clue as where to find.
______________
Totally Wired Beetle
2003 Platnium Grey Supercharged
Old 11-08-2006, 05:12 PM
mgwerks's Avatar
Cherchez la coeur...
Bandera, Republic of Texas,
Car: Oso - a black 99 GLS TDI
like $5 on eBay
Your fog lights are on,
It isn't foggy today -
You are a doofus.
Old 11-09-2006, 12:44 PM
FallinApartBoy's Avatar
I Want A 2.5T
Dayton, OH, USA
they arent too bad on crutchfield.com either
Old 11-11-2006, 07:37 PM
OldSkoolVWLover's Avatar
Rusto King
Sac, CA,
Car: See Sig
or enfig.com
just so you know, if the radio died, it is probably dead or another problem. I have NEVER blown a fuse on a deck, blown plenty in the fuse box.
Check it, but unless something has changed wiring wise in the car, it would be an odd one to blow in a factory setup. Good luck
Old 11-13-2006, 02:59 PM
how does a radio just die? the lighter socket under the dash is also not working which is why I assume it's a blown fuse, but the fuse diagram is pretty useless.
Old 11-13-2006, 06:16 PM
Rusto King
Sac, CA,
Car: See Sig
start pulling fuses...... with a lil time looking the fuse diagram will make a lil sense. You said you checked the fuses already though????? I am confused, if the lighter is out too it is probably a fuse... then you say you checked the fuses. The fuse on the back of the radio would have nothing to do with the operation of the lighter. Go back thru and pull each fuse if you have to...... a fuse tester would be good too if you are having a hard time identifying the trouble.
Old 11-13-2006, 08:33 PM
BUGSTUFF's Avatar
New Beetle Accessories
Bartlett, IL, USA
Radio fuse is number 37. Should be 10amp. Monsoon fuse is number 42. Should be 25amp. Cig lighter fuse is number 41. Should be a 15amp. A stereo install shop should be able to pull the radio for you if you don't want to purchase the tools.
Good luck!!!
Kirk & Pam & "Key Lime"
Northeast IL VW Association
Volkswagen Club of America
Old 11-13-2006, 10:44 PM
Sadly, your radio can die via jump starting. It happened to me when I got 'Cup jump started. Hopefully this is not your case. Oh yeah, if you need a radio removal tool, PM me and I'll make you one and send it to you free of charge.
Radio Removal Tools Question teklein Car Audio 2 07-16-2006 11:36 PM
Looking For Radio Removal Tools MOONDOG316 Market Place Archives 10 02-11-2006 03:00 PM
Factory Monsoon Radio and XM Radio GirlNextDoorTn Car Audio 1 12-15-2005 09:22 AM
