Rear Speakers - Low volume - NewBeetle.org Forums
Old 01-24-2007, 01:02 AM
worbc's Avatar
Tustin, CA, USA
Default Rear Speakers - Low volume
I have a 1999 TDI bug, I just installed 2 sets of 6 ½ in 2 way (6012si) Infinity speakers. The front pair work great, the rear have very low volume, they are identical pairs.
I have an aftermarket, pioneer DEH P9300, using OEM wiring.
I was very careful making sure no wires are grounded out. I've got the bug's wiring diagram and can locate no physical device that should be limited the volume.
Any ideas?
--terry
--terry
-_-_-_-_-_-_-_-_-_-_-_-_
Terry (WORBC) Rector
1999.5 NB with following modifications, VR6 Clutch & Lightweight Flywheel, CARACTERE body kit, Special modified exhaust with Magnaflow Muffler, Three Gauge Pod with Boost, Oil & Water temp gauges, Rocketchip Stage III, Sprints 520s, ProSound System, ProVent CCV
"You can't build a reputation on what you're going to do." Henry Ford
Old 01-24-2007, 01:56 PM
IceDog's Avatar
((( XM )))
Mississauga, Ontario, Canada
Car: 2k Techno Blue Beetle
Check the fade? It's possible you have it so all the sound is coming from the front and not equal between front/back.
Old 01-24-2007, 03:34 PM
jdesigns's Avatar
Just because!
Puget Sound, WA, USA
Car: Black '03 Turbo S New Beetle
Monsoon or not?
I've got the Monsoon, and that is just the way the amp is "balanced". You could try to fade more toward the rear speakers to get more sound, but then you are also using more volume to get the same levels of sound. (That is what I do at least)
BTW, the door speakers are only used for the bass frequencies.
Your best bet would be to add a 4 channel amp to fix it.
Science flies you to the moon...Religion flies you into buildings
Old 01-31-2007, 08:23 AM
Warren, OH,
Car: 2000 Beetle
You do realize that for proper sound your rear speakers should be at a lower volume. All sound should come from in front of you and set a "stage" Rear speakers are only good for rear fill and should be turned up till you just barely hear them. Some people put separate volume knobs on rear speakers just to turn them down.
Me I don't have any rear speakers. Just two 6.5's in the doors, two 4's in the dash along with two tweeters and another set of tweeters in the stock location. One 12 in the back for bass.
rear speakers toytle Car Audio 3 09-27-2006 06:28 AM
New Low Low Price Black Leather Heated Seats turbs01 Market Place Archives 3 07-29-2006 10:00 PM
Stock Rear Speakers BigRedOne98 Market Place Archives 0 05-11-2006 04:18 AM
Monsoon Rear speakers sound weak XCman Questions, Issues, Concerns, or Problems with the New Beetle 0 04-10-2006 03:48 PM
Rear speakers install help [lot] Car Audio 6 10-22-2005 05:25 PM
