Yes, the "K" wire is designed to carry data and some low level voltage (not like that from audio gear or the battery), but no, the rest of what you have stated is not necessarily true and it is not the entire issue, the "K" wire is not suppose to be connected to any cable that generates any high level hard voltage at anytime, regardless of whether the Head unit is on or off.
High level voltage entering the "K" wire does not only put a vagcom at risk of damage but it can also cause damage to your vehicle/ECU etc. FYI folks, do not connect the "K" wire at all when using a head unit other than the factory piece, make sure that the "K" wire is connect to nothing (Not Terminated) and that the end of it is heat-shrinked (Insulated).
This is true! I had my cd player in my 99 nb done at best buy and it failed emissions becase it was unable to read. In the state of nj when u fail emissions you can only have your car fixed by an emissions repair facility and they have to sign the paperwork saying that they fixed it so that they will reinspect your car. Only thing is there wasent anything wrong with my emissions so the repair facilties couldnt fix it and they couldnt sign the pappers saying that they did so i couldnt get it reinpected. I had to rive around with a failed sticker for amost a year! I finally got a k wire put in by vw (who had me take the car elsewhere to get the radio removed and put back in after the k wire was installed. they would not touch it at all!) and then i still had to wait out the time alowed for reinspection becase vw is not an emissions repair facility and they could not reinspect me even tho it had been fixed by vw. It was a nightmare! I am sooo glad my new nbc has a cd changer so i do not have to go thought that mess all over again!
So true you would have passed emissions if the diagnostic computer would have been able to connect in the first place. Unfortunately they probably don't have an exception box saying "Retest when diagnostic tool is able to communicate with ECM." or "Diagnostic tool error, free retest when communication issue is resolved." ![]() |
SoCalnewbeetleclub |
Don't hold me to this because it's been awhile since I've had to deal with it, I believe it is brown and yes, the "K" wire should not be terminated, connect it to nothing and insulate it so it doesn't contact anything.
Installed aftermarket stereo and now SEL is on. Took to dealership and was told the radio was interfering with computer. What do I do? Take it back to Best Buy and have them install the radio correctly? Anyone have any answers? I don't have original radio anymore so I can't install back.
This is my suggestion: Go back to Best Buy and speak with the store manager, not the shop manager, not an inside floor manager, not an assistant manager or supervisor, speak directly with the manager of the entire store. Explain to him/her that the installers at facility have caused electronic issues with your car by improperly installing your stereo head unit, this has been documented by the Volkswagen dealer. Explain that you are going to take the car to an audio specialist in order to have the head unit reinstalled correctly because you no longer have confidence in Best Buys abilities, let him know that you expect a full refund of the Best Buy installation charges as well as reimbursement for any repairs that might be required as a result of this. Maintain documentation of everything. |
re aftermarket radio & Best Buy
had radio put in wrong at Best Buy last year failed inspection in NJ because the computer couldn't be read found this thread THANK YOU TOO COLD!!!!!!! Went to another Best Buy (Manahawkin) Got this awesome tech, Jack, who researched the problem fixed K wire issue free Passed inspection. Have a 2000 Passat original monsoon radio for sale |
Ok I've been hearing that when you put an after market radio into the New Beetle it doesn't pass smog. Well I just had my NB smogged and it passed with flying colors. I think if the guy who installs your after market radio knows what he is doing and stands behind his work like my guy at New Age Audio in Fullerton (ask for Milo), the NB will pass smog. If your guy writes "may not pass smog" on your radio installation receipt, obviously he doesn't stand behind his work and you need to take your NB elsewhere for an after market radio installation. I passed smog, I'm listening to my tunes on my Alpine driving my NB and life couldn't be sweeter! Just wanted to share the 411 on that dilemma. Take care of your New Beetle by taking it to a guy that knows what he is doing and stands behind his work. Good luck!
Let The Good Times Roll, Rachel VW BEATL |
The radio has nothing to do with the actual smog test, in -California- there are a number of areas that makeup the smog test.
The one area that will cause you to fail a California smog test as a result of a non stock head unit having been installed incorrectly are, DTC's (fault codes). Any engine DTC's will fail you before you get started. |
I too have heard that if you pop off the faceplate it can allow communication with the ecu. Not from personal experience, but from a tech friend.
I swear my real name is not "Wienerdude" 2003 1.8T Beetle ![]() 2001 Jetta 2.0
| Moving to California, smog check question | Sunshine78 | 2.0 Liter Gas | 5 | 09-03-2006 04:05 AM |
| MY00 Factory tape player w/CD changer and bra | 1pt8t | Market Place Archives | 4 | 07-13-2006 06:04 PM |
| EZ Pass | FineExampl | Questions, Issues, Concerns, or Problems with the New Beetle | 15 | 06-03-2006 02:13 PM |
| Fs: Factory Cd Player (new) | 1beetle | Market Place Archives | 27 | 05-16-2006 05:31 AM |
| 2006 In Dash Factory Cd Player ~All Offers Welcome! :-) | JuggBug | Market Place Archives | 4 | 03-22-2006 03:20 PM |
