Remove radio/check engine light warning?? - NewBeetle.org Forums
Old 06-26-2007, 02:46 PM
apodaca's Avatar
Beetle Newbie
Tampa, FL, USA
Car: 99' NB 2.0 "Bella"
Default Remove radio/check engine light warning??
Okay so I went to the dealership yesterday and was inquiring about adding an aftermarket radio to the NB. The lady at the counter said she reccomends against it due to the check engine light misreading when changing to an aftermarket radio. She said the fact radio is tied into the computer and will misread when installing my radio.
Is this true, or was she blowing smoke...you know where?
Old 06-26-2007, 04:33 PM
Don_n_Herbie's Avatar
TDI Lover
PARMA, OH, USA
Car: 2003 GLS TDI Platinum Gray
She is very misinformed
There are alot of us that have installed aftermarket radios in our Beetles. The only thing you have to do is when installing it is to make sure not to hook up anything to the K wire.
If you hook up the K wire the only thing that will happen is to mess up any scan tool that is hooked up but any aftermarket radio will not trip the check engine light.
Old 06-26-2007, 04:46 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
I know what your next question will be...
SoCalnewbeetleclub
Old 06-26-2007, 04:52 PM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
I just put a Sony in mine. Don't listen to her.
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Old 06-26-2007, 06:39 PM
noR's Avatar
Administrator
Jackson, MS, USA
Oh she knew what she was saying. The trick is to leave that k-line off the new radio though.
But that's true, it'll show up in future scans as if the radio wasn't there. (since it's not plugged in) Big woop!?
But some dealerships will refuse service [because if the k-line ISN'T removed, and is plugged into something like 12v.... it'll cook their $30K computer] if there's an aftermarket headunit. Ask your service writer.
noR | me | Phrog
PHROG
Old 06-26-2007, 07:14 PM
apodaca's Avatar
Beetle Newbie
Tampa, FL, USA
So the trick is just say no to the K line. I just bought an install wiring kit. I dont have it yet, but would you think the diagram on that would indicate the same as you're saying? If not, is there a color wire I should look for?
Brake Light, Check engine light, air bag light, but wait theres more djack19 Questions, Issues, Concerns, or Problems with the New Beetle 15 11-09-2011 10:13 AM
check engine light on - again ladybugz84 New Member Forum 4 12-07-2006 01:20 AM
HELP! Check Engine Light keziah23 2.0 Liter Gas 7 10-21-2006 02:37 PM
check engine light Skylife Questions, Issues, Concerns, or Problems with the New Beetle 2 07-21-2006 06:29 AM
Check Engine Light superbeeyellow 1.8 Liter Turbo 4 11-05-2005 07:41 PM
