I'm looking to upgrade my audio system. I currently have the stock monsoon system with an Alpine deck upgrade. I think I'm ready to go the subwoofer route.
I listen to a lot of different music so its a bit confusing on what will sound best. Anything for country to rap/r&b to alternative punk. All types. I'm trying to keep it clean and simple. Ive narrowed it down to JL components. I'll most likely be running a 500/1 amp and either one 12w6v2 or two 10w3v3. If I go the 12w6v2 route I figured I can always add another later on but really only want to do this once. As of now I am on a budget of $800-$1000. Thats what I'm saving for anyway. I want to build a fiberglass bog and have it matched in color to the car for a nice clean appearance. What do you guys think. I need your HELP! Also if there are any other recommendations I am open to suggestions.
Photo's Uni Red 1.8T SOLD
I have 2 10" in my car right now, and they sound great. You can get them to be crystal clear or just drown out everything else with deep base. They're really versitle. I also have my old box, fits 2 10s, that i'm getting ready to sell, it is the one in the pictures of my bug. Not the greatest looking but you can get some great sound out of it.
Check out my MySpace Say hello to "TS" Want something to give charactre to your bug, check this out |
I'd go with the single 12 for now, not that I am bias or anything. I went with 2- 12" RF T1s with a RF bd1000. It all depends on how you tune it to your listening needs.
it all depends what you want. i have 2 mmats pro audio pro cast 12's and a mmats 1400 watt class d amp. sounds great. can be loud when needed. but i usually keep the subs turned up about a quarter of the way.
it all depends on what your looking for, the w3 is more of a sound quality woofer, but the w6 is for making loud bass. If you're gonna do mostly rock/country, i'd go with the w3's. a single 12" w3 would probably sound as good (and be more versatile) than 2 10's because it will be able to handle the lower and longer bass frequencies of rap/r&b (and some country songs) better than the 10's, but at the same time, be able to do the faster bass of punk.
but that's just my opinion. I'm running a 12" alpine type S sub in a small sealed box, and only giving it 280w rms. and it sounds awesome in everything i play. i'm thinking of putting it in a ported box, but then i'd lose some sq, but gain alotta db.
Well just my 2 bits here.... I just put a single Rockford Fosgate P2 10" into the back, in one of those Magnaform MTX boxes that mimics the shape of the trunk.
Running that on a Pioneer GM3300T amp and you know what? There's a LOT of thump *or boom* in the back , depending on how I tweak it via the Pioneer DEH-690UB. It's very clean sounding, no distortion, but plenty of bass ![]()
Bumbls : 2011 Ford Transit Connect XLT
Sting : 2002 1.8T Beetle Color Concept My FLICKR: See My High-Res Photos Here Cameras I Use: Canon Eos 40D |
Really either one will suit you but think about your trunk space and how much you want to keep. Figure out how you want to mount them in your trunk. The box, amp and signal are just as important as your sub and can really change how it sounds. You can make a larger sub sound quick and crisp with the right box, and the same goes for smaller subs with deep low bass. Most 10" subs need atleast .75 cu. ft. and most 12's need over 1 cu. ft. of volume. If you plan out the rest of the stuff then no matter what size you get you can get some great sound out of it.
I have a single jl audio 12w7 in my beetle and I LOVE it! You couldn't pay me to use a different sub I love it so much. I used to have 2 10w7's in there but it was too much weight for my taste and the single 12 seems just as loud as the 2 10's. I'm sure the 10's could play louder but in our cars it gets stupid loud quick and the 12 seems like it can play as loud as I ever turned the 2-10's. My girlfriend has the 12w6v2 like your looking at in her suv with a soundstream van goh 5 channel amp similar to the jl amp your looking at and it sounds great. Sounds really similar to the w7, perfect with every kinda music. I think you'd like the single 12 more than the 2-10's
Thanks for all of the input everybody. I'm still up in the air about all of this.
This week I went down to talk to the audio guys ant the local stereo shop and he recommended a 13w6 over the other two options. He showed me a chart about air movement vs the other two and a 13w6 will move 89% more air than a 12w6. Mathematically it seems the best route. I also asked him about the recovery rate with 10's vs 12's, and he said if powered right they will keep up just as good. I think most people under power bigger subs so that may be the issue. Has anybody ever heard of Zapco amps. The guy recommended them over the JL since they are a better amp. Zapco does only amps so it makes sense that a company specializing in only amps would be better than anybody else. The Zapcos are also an A/B class instead of a D class like the JL. I really don't know exactly what that means but the end result is a cleaner signal. Hopefully I make the right choice. I have some time to decide since I am still saving up for the equipment. Trunk space is really not an issue. If I want to haul anything large I use my wifes Passat for that. I think I want an install more toward the "show quality" than the "I can still use my trunk type." |
Pics of Layla, my 1998 New Beetle http://newbeetle.org/forums/showthre...106#post303106 |
I've heard two others that were the MTX sub with the MTX built in amp.... and it was *clean*... but I think that the P2 has more power for the size, it definitely hits lower, as well as harder. Of course this is my opinion. I've run speakers from 15" Orion XTR subs, 12" Pyle Pro series (USED to be competition class, now they are great entry level subs), Pioneer 12" Free-air subs, Rockford Fosgate 10", as well as a few generic subs I can't for the life of me remember what they were. And an Infinity or 2, plus a couple various MTX's in years.... and Phoenix Gold. They have *all* worked nicely to different degrees. But this P2 is VERY nice. Very clean, no distortion. |
As far as zapco, I've had zapco amps in the beetle also. The competition series are frickin awesome amps. They're other ones are about on par with the jl amps. The problem with them is that they cost so much, and they are kinda finicky. I had a c2k 9.0 for my subs when I had 2 10w7's and when I kranked it I could make the amp shut down for a second on hard hits and that's with a second battery and a 40 farrad cap!! It did sound very clean though. Your shop was right that a class a/b amp will sound better than a d class amp. If your shop sells jl audio, have them show you the w7's. I think you will like them ![]() |
i put a 15' in my trunk, its perfect for me... haha, if i had the option of 2 10's or a 12 though, i would do 2 10's, my buddy has 3 jl 10's in his beemer, with mbquarts, (both runnin seperate amps,) and it is probably the best sounding, cleanest in all music catagories system i ever heard!
the box will make the main difference in sound....if you dont listen to rap all the time then dont get a ported box....i vote 2 10's in a sealed box
| Got the bug in the 12's..GTO into the 10's | Holland | 1.8 Liter Turbo | 13 | 04-22-2007 02:10 AM |
