I'm trying to install a Sirius satellite tuner into my 2003 New Beetle. I've run the antenna to the dash, that was the easy part. My problem is placement of the tuner.
This is a hidden satellite tuner that will be controlled by my aftermarket receiver. This is a box roughly 4"W x 4"D x 1.5"H. I'm having the hardest time find a spot for it. I'd rather not install it under the passenger's seat. I'd like it somewhere underneath or inside the dashboard if possible. Since the dashboard is big enough to take a nap on, I thought for sure there would be plenty of good places. But I'm not finding them. I've searched all over this forum, but can't see to find any suggestions on where to put it. 99% of the Sirius/XM threads deal primarily with Roady-style receivers. I was 2 seconds from riping out the center console facade before I decided it might be better to ask around the forum. Any ideas? |
I have 3 parts of mine hidden away in my dash. The main part of my headunit is under the carpet at the highest point of the passenger floor. I have my Sirius and add on EQ in the dash, one box is behind the black panel above the pedals and the other box is dash area where it mets the floor at the cupholders.
I have the black box Sirius tuner mounted under my dash. When you take the center cap off your dash and take off the passenger side top dash panel, you will see a small amount of space behind the airbag. Mine has been in the for a couple months with no issues. It was also very easy to run the wires as it was right next to head unit.
Pics of Layla, my 1998 New Beetle http://newbeetle.org/forums/showthre...106#post303106 |
All done. I tore out my glove box hoping to find a decent place, but couldn't really find one. Though, with the glove box out of the way it was easier to mount it up under the foam under the dash on the passenger's side. Also with the glove box out of the way it was easier to feed the wires to the stereo.
The hardest part was putting in the new pioneer head unit. That damned thing just didn't want to go in. There is just barely enough room behind the unit. If you've got wires crossing from left to right, there isn't enough clearance between the back of the unit and the dashboard stabilization brace at the back of the DIN slot. After an hour of trying to jam that sucker in there I realized this to be the case. I then took my AUX line and Sirius control cable and fed it behind this brace to give me just enough extra clearance to fit the stereo into the slot. I wasn't able to use the snap-in Metra facade that I bought. It just doesn't work well for removable faceplate stereos (or, just my removable faceplate stereo). I hat to settle for the facade that worked in conjunction with the stereo's trim (against my better aesthetic judgment. One last step... Reassemble my dash. Thanks for the suggestions. |
Oh I'm definitely not brave enough to put it in the door. I'm surprised by how little free space is available anywhere else though.
This was my first stereo install, and all in all it went pretty good. Though I did leave a couple of small unsightly scratches here and there. Of course, now I know to put masking tape everywhere for protection. Beginner's mistake. D'oh. Oh, and I also have two spare Torx screws. ![]() |
http://i95.photobucket.com/albums/l1...s/SSPX0203.jpg |
| Satellite Radio | Jellibean83 | Car Audio | 11 | 01-02-2009 07:15 PM |
| To Hide the Garage Door Opener? | Hopkins | The New Beetle Experience | 15 | 02-21-2007 05:21 AM |
| Satellite Antenna | ghostRder1 | Car Audio | 0 | 07-13-2006 02:31 AM |
| Satellite Radio | pdoel | Car Audio | 56 | 01-30-2006 07:18 PM |
| Beetle ZipConnect Speaker System with AM/FM Digital Tuner & Alarm Clock | BlooBug | New Beetle/Volkswagen Toys | 4 | 12-27-2005 10:29 PM |
