I'm looking to see if anyone has pictures of this process. I've been told you need to drill out the riveted spreakers, front and back. Plus I was told the back speakers need an act of GOD to remove. I wanted to start, but was interested to see if anyone else has done it. I might be persuaded otherwise.
http://i95.photobucket.com/albums/l1...s/SSPX0203.jpg |
The rear panels can be removed without taking out the back of the rear seat. I would recommend taking out the bottom of the rear seat for the extra room. To me the a-pillar tweeter was the hardest to remove, all the rest were fairly easy.
As NBTurboFreak said you can remove the rear speaker panels quite easily with your hands,
there's no drilling required to replace rear speakers, those have screws on them so replacing those should be simple. Front speakers I have not replaced, and I've read those do require drilling some rivets. Hope that helps
+ GIAC Chip + K&N RE-0932 Cone Air Filter + MagnaFlow 2.25" Stainless Catback + Audi S3 Lower Wishbone Brace + Sony CDXGT610UI HU + JBL GTO637 Speakers + Kenwood KAC6402 AMP + Pioneer 8" TS-SW841D Sub Last edited by Byros; 09-08-2007 at 02:50 PM.. |
Front speakers don't have the screws they have rivets. You'll need to drill them out. Make sure the old rivet doesn't fall into the door as they can be a real pain to get back out. Watch what size speaker you get as the spacers don't like the gas flap/boot release switch. But a little modifying gets the switch back home comfortably
![]() In the rear they are just screwed into a metal plate. You'll find it a lot easier if you remove the rear lower seat, there is no need to remove the rear seat back. The rear cards just pop off and on the drivers side there is the interior alarm sensor button to unclip. Will take approximately 5 mins to remove both rear cards. I removed the metal housing too, as it's now given me room to put amps and 4 X 8" speakers and 4 X tweeters in there. Reccomend JL audio, Kicker, or if your going cheap C4. Have Fun getting the rear cards back in place, there a real pain in the as s ![]() P.S. The speaker size factory wise is 6.25 not 6.50 ![]() |
I just purchased a set of Polk dB6501's for the front. I haven't tackled the install yet.
http://www.polkaudio.com/caraudio/products/db6501/ ![]() http://www.crutchfield.com/S-DcmBa9z...sp?I=107DB6501 In the rear I just installed the Polk dB651 coax. They were VERY easy to install. They were a perfect fit without needing to use the included mounting ring. They do sound nice and clear. http://www.polkaudio.com/caraudio/products/db651/ ![]() http://www.crutchfield.com/S-DcmBa9z...1&search=db651 Now if I could just get a day off, I'd be able to get the fronts and my sub installed...
Pics of Layla, my 1998 New Beetle http://newbeetle.org/forums/showthre...106#post303106 |
Now that's what I was asking for in the begining of this thread. PERFECT! Now I know what to expect when I try to tackle mine. Do you have pics of the front too? If so, post away. I didn't realize it would be so easy to mount seperates in the back. I was originally going to put just your average 2-way in the back, but after seeing your picture, I think I changed my mind. Again thanks for the pic.
PS Do the rear or front mounting locations have speaker baffles, or a sealed enclosure? Just curious how the factory speakers respond at the lower frequencies so well. |
Will will try to get some pics of the front setup if my door panels behave for me. The car just is sitting in the garage waiting for the motor to be rebuilt. I am running 6.5" RF FanQ comps in the rear and front. I added a 3.5" RF speaker in the dash to utilize the Monsoon stock locations. It is unbelievable how clear and define the music is, maybe not with hard rock, rap, or bass cds. When I would go visit the stereo shop for an upgrade or something, my installer would just sit in the car and admire his work. He said the Beetle, in general, was the best sounding vehicle he has ever gotten to work with in his 15 years.
For the rear tweeters I have some custom covers made to look like the a-pillar tweeter triangle grills that I need to get repainted to match the CC interior and mounted. Where the rear factory mounts is on a metal sheet, the part that is wrapped in dynomat. There is no sealed area or anything. |
Here are some pics of my front speaker install:
Please pardon the dirtyness right now, the car has not been on the road for about 11 months at this point. The door: ![]() ![]() The front tweeter: ![]() The dash speaker (in keeping with the monsoon setup): ![]() ![]() |
I work on my Pizco page a little and made just an I.C.E. page
Those highs must be so CRISP! I had a similar setup in a previous car. 2 pairs of Kenwood separates ([2] - 1 in tweets and [2] 6.5 mids). And for the subs 2 RFosgates 12's. All running off of a 60 x 4 amp. Now I know what you're saying. 240w RMS for all that aint nothing. It was all I needed. I have everything waiting to be put in my bug now, minus the 2 pairs of separates.
NBTurboFreak - that looks great! What did you use to mount the front tweeter in the a pillar (the black goop)? Could you go into how you did that a little more?Thanks - Jonathan |
| ne1 near pittsburgh? | vdub11 | Event Planning Archive | 7 | 04-20-2007 03:33 PM |
| Greddy FMI. install pics. | speedsk8er | Technical Modifications | 8 | 03-25-2007 08:49 PM |
| Does anyone have pics and instructions for a water and oil temp gauge install? | worbc | Technical Modifications | 0 | 03-06-2007 12:33 AM |
| Aftermarket deck install..... pics, smooth mount | OldSkoolVWLover | Car Audio | 2 | 12-21-2006 07:15 PM |
| beetle pics link before suspension install | degny21 | Technical Modifications | 0 | 01-05-2006 05:20 AM |
