XM receiver location questions - NewBeetle.org Forums
Old 09-16-2007, 01:09 AM
hadda61beetle's Avatar
Greenleaf, WI, USA
Car: '07 Laser Blue NBC; '05 Passat Wagon TDI; '99 Ford F-150 4x4; '23 Ford T-Bucket
Default XM receiver location questions
Okay, now before everyone goes basllistic on me...I looked over on the XMFAN.COM for any installation pictures dealing with a 2007 VW NB convertible and I found only one item dealing with some fella who had bought a 2007 NB Vert and it was radio ready with Sirrus and he wanted XM.
I had XM installed on my '99 F-150 Ford truck two weeks ago and now I want it on the VDub as I'm addicted to it now.
My question would be this...where do you suggest I mount the bracket that holds the receiver? It has to be clean looking and NOT mounted on top of the dash.
Second question, to get the car kit for my particular model XM, I have to go through the factory. How difficult is it for one to connect this XM receiver bracket and power and antenna? I'd rather do it myself and save myself the cost of having to take it to Best Buy.
Your input is greatly appreciated here. Thank you in advance.
Jerry
Old 09-16-2007, 02:32 AM
hestersu's Avatar
Canyon, TX, USA
What year model NB do you have? Hard top or vert? I know where the receiver is installed on NB's that came from the factory with XM or Sirius. Are you looking for a factory like install? Or are you going with an aftermarket install?
Susan Hester
Former owner of:
Old 09-16-2007, 04:35 PM
Greenleaf, WI, USA
Susan,
I have a brand spanking new 2007 NB Vert. Just picked it up yesterday morning at 10:30AM. I wish it did have it already in the radio, but alas this will be an after market attachment using one of their car-kit brackets. It's fine where it is located in my F-150, but when they mounted it in my wife's '05 Passat TDI Wagon, it went on top of the dash. I do NOT want it there.
So yes I require inpit. According to the leetle icons next to my posting, it reads that I should go back and re-read the initial posting regarding this subjuect. Now I have to tell you , I'm still learning to navigate my way around on this site as well as learn what all the leetle icons mean.
Jerry
Old 09-16-2007, 11:45 PM
hestersu's Avatar
Canyon, TX, USA
First, call back to the dealer and talk to the parts people (not the sales folks) and give them your VIN. Ask if they can confirm if your radio is satelite ready. In the beetle, the receiver is not part of the radio - the radio just has to be sat ready. If it is (I suspect it is), the receiver goes up on the firewall in the footwell of the passenger side under the carpet. There is a site where you can actually buy an OEM receiver - XM or Sirius. Then its a case of running the wire over to the radio and to the antenna. The antenna can actually go under the center dash cover and work quite nicely.
I need to contact a friend who actually switched his Sirius for XM. He traded his and hooked everything up and it all worked.
If you want to do your own install with non-oem parts, you can still mount the receiver in the same place and mount the antenna in the same place and put your control module where ever.
Good luck.
Old 09-18-2007, 07:01 PM
Default XM Mount
I have this mount for my Sirius radio, should be the same. It mounts to the left side of the grab bar on the passengers side.
- Jeff
http://www.crutchfield.com/S-I0TPkun...50&I=042VW5298
Old 09-19-2007, 03:48 AM
Greenleaf, WI, USA
Default Plummkrazy & hestersue
Plummkrazy,
Thanks for the input regarding the mount for my XM. Sue, I do not have a satellite ready radio. Sue, I called the parts department at my dealer and he inquired if I have the letters SAT on top of the right radio knob. He said that I do not have a satellite ready radio. No problem, I'll just go online and hook up with XM.
Thanks you two. Is this a great sight or what?
Jerry
I wanna change CD receiver but not a OEM CD changer. ksg891004 Car Audio 0 02-20-2007 11:18 PM
I wanna change CD receiver but not a OEM CD changer. ksg891004 Technical Modifications 0 02-20-2007 01:46 AM
cheap in-dash dvd receiver w/screen? bobbittle Car Audio 0 10-05-2006 11:27 PM
DIY hitch receiver for bike carrier? Bugster Paint and Body 9 05-26-2006 09:36 PM
Sattelite radio receiver? Deserion Car Audio 3 01-12-2006 12:44 AM
