Well, I don't know much about the depth in the doors and whatnot, but if someone had previously altered the stereo setup, the monsoons are probably just fine, but they most likely either had an aftermarket amp installed, (and then pulled it, so nothing is connected to the front speakers).. or they disconnected the Monsoon amp under the rear panel.
My cousin just got a 2002 Jetta 1.8T with a Monsoon.. and he couldn't figure out why none of the audio works. I took one look in it and it was an easy answer for his. All the speakers were upgraded, and the deck. In the trunk, hidden behind a panel, we found a zero gauge power cable, 3 sets of RCA's and all the speakers wires. They had been running a 5 channel amplifier for Sub and speakers and then when the car came to the dealer, the dealer remove the sub and amp, disabling all the speakers without realizing it. they are getting the amp and sub back for him so it will work. It's possible a similar situation happened with yours. Could just be a matter of re-connecting wires ![]()
Bumbls : 2011 Ford Transit Connect XLT
Sting : 2002 1.8T Beetle Color Concept My FLICKR: See My High-Res Photos Here Cameras I Use: Canon Eos 40D |
If you do need new speakers, you will have to take depth into consideration. If you look at thefactory speakers, they actually mount in hte middle of the spekaer depth instead of right at top, so they stick out about an inch on both sides of the door panel.
I remedied that by mounting my door speakers to the door cover instead of to the door itself, but there are mounting spacers available, if you want to go with a deeper speaker, and keep the factory look.
New head units are dirt cheap and just a decent pair of 6 1/2 wont set you back too much. http://www.crutchfield.com can help you get something nice and without spending a lot of $$$ |
| Woofers from Whitedog | whitedog | New Member Forum | 14 | 11-16-2006 04:04 AM |
| Monsoon amp and factory speaker replacement | '01vwbeetle | Car Audio | 1 | 10-20-2006 11:12 AM |
| Monsoon speaker replacement | KevinR | Car Audio | 4 | 06-30-2006 11:10 PM |
| rattle in Monsoon door speaker... | sledmeister | Car Audio | 7 | 04-07-2006 04:45 AM |
| Monsoon HU replacement using crutchfield kit | sledmeister | Car Audio | 4 | 03-26-2006 10:05 PM |
