fuse question! - NewBeetle.org Forums
Old 10-10-2007, 11:19 AM
dmk's Avatar
dmkRegistered Member dmk is offline
Default fuse question!
Hey org'rs, have another question I need a simple answer to!
I am re-installing my system from my old car (which i had a shop do), but i left the amp power cable with in-line fuse int he car for the new owner.
my question:
What size in-line fuse should i be using?
I have a 1000w Kenwood amp powering a single 12" sub.
Thanks everyone
'99 Techno Blue 1.8T New beetle.
APH engine, 5spd
It's not hard to fail,
it's not easy to win!
Old 10-10-2007, 04:17 PM
apodaca's Avatar
Beetle Newbie
Tampa, FL, USA
Car: 99' NB 2.0 "Bella"
Is it 1000w rms, or peak?
Old 10-10-2007, 11:18 PM
dmk's Avatar
1000w peak I believe. at least that is what it says on the amp!
Any ideas?
I believe it should be a 100... correct?
Old 10-11-2007, 03:53 AM
apodaca's Avatar
Beetle Newbie
Tampa, FL, USA
What I've always done is match up the fuse rating on the amplifier. ie: If the amp has a 40a fuse, then match it. That is, if this will be the only thing fused off this power line. If the amp has multiple fuses, then add them. ie: 3 x 15a fuses would equal 45a. It won't hurt to go over. It's just not neccesary. Just make sure the fuse is as close as possible to the battery. You dont want it inside the car. If it grounds you'll need a fire extinguiser.
I hope this helps.
But for 1000w peak would be about 500 rms. So I would say about a 40a - 50a.
Old 10-11-2007, 04:10 AM
afinley's Avatar
Cold Buggin'
Raleigh, NC, USA
Car: 04 black BTS
all that was wrong
the fuse is for the wire, not the amp. thats why the amp has its own fuses. the fuse size is detirmined by the size and length of the power wire. go to
http://www.bcae1.com/fuses.htm
for a full chart.
You want the fuse as close to the battery as possible, because all the wire between the fuse and battery is an extreme fire risk, especially in a crash.
no matter what, use the smallest fuse you can without immediately blowing it.
Unitronic Stage 1+, 3" DP, Venair TIP, Forge 007, Venair Boost Hoses, Swiss Airbox, "Free Flowing" MAF.
25 psi of fury.
Old 10-11-2007, 06:06 AM
dmk's Avatar
great link!
Thanks... the more info the better!
Old 10-12-2007, 04:52 AM
apodaca's Avatar
Beetle Newbie
Tampa, FL, USA
Sorry, forgot to factor in the wire guage. Ditto on the good link.
Help with fuse?? kswatso Questions, Issues, Concerns, or Problems with the New Beetle 7 07-13-2007 12:27 AM
fuse?? kswatso Questions, Issues, Concerns, or Problems with the New Beetle 2 07-09-2007 01:02 AM
Fuse Help! justjames New Member Forum 6 02-19-2007 02:25 AM
Fuse Help! justjames Questions, Issues, Concerns, or Problems with the New Beetle 2 01-22-2007 01:00 AM
what is this fuse for?? tahn_a 1.8 Liter Turbo 6 08-19-2006 05:19 AM
