HeLp....aftermarket stereo and airbag light - NewBeetle.org Forums
Old 10-29-2007, 05:03 PM
NJ, USA
Car: 2004 GLS Silver
Default HeLp....aftermarket stereo and airbag light
I'm sorry if maybe this topic is already posted.
I just had an Alpine installed into my 2004 Beetle GLS with Moonsoon speakers. I wanted the ability to play my ipod.
3 days after it was installed my Airbag light came on.
Dealer says they can't read it with their diagnostics because of the aftermarket stereo. The wiring was effected. My airbags will not go off now if i'm in an accident.
They said to have the radio installer re-install the old stereo to factory settings in order for them to read why the airbag light is on.
anyone had this problem?
Old 10-29-2007, 10:50 PM
Custom Fabricator
South Florida, FL, USA
Car: 2002 New Beetle TDI
you really should take it back to the shop that you had do the install. if that is too difficult try disconnecting the battery for at least 3-5 minutes.
good luck
greg
Old 10-30-2007, 08:06 PM
afinley's Avatar
Cold Buggin'
Raleigh, NC, USA
Car: 04 black BTS
a: the scanning issue is only on stereo's before 02.5, newer ones dont have the wire that could possibily be a problem.
b: the installer needs to fix it
c: it is usually something like "intermittent dash light failure"
d: if you know anyone with a vag-com, they can scan it. if they're worried, you can take off the face plate, and there is no risk of shorting anything out.
Unitronic Stage 1+, 3" DP, Venair TIP, Forge 007, Venair Boost Hoses, Swiss Airbox, "Free Flowing" MAF.
25 psi of fury.
FS: Aftermarket stereo install parts Woz2000 Market Place Archives 4 07-02-2007 04:43 PM
Airbag light TarHeel Beetle Questions, Issues, Concerns, or Problems with the New Beetle 1 01-18-2007 01:25 AM
Airbag Light On, Now Off? jbthompson Questions, Issues, Concerns, or Problems with the New Beetle 14 12-15-2006 04:01 AM
airbag light Shay Questions, Issues, Concerns, or Problems with the New Beetle 19 11-20-2006 08:19 PM
will aftermarket stereo be able to control factory CD changer? ppp_369 Car Audio 1 10-17-2006 06:57 PM
