you dont need to worry about the RMS rating of speakers when you already have the amp.
the monsoon amp also houses the crossover, what split the low tones to the woofers and the high tones to the tweeters, so it will not be much of an upgrade unless you replace the whole amp.
to be honest the monsoon speakers are pretty decent. a way better route would be to get a decent sub and amp, and run some bass blockers on your front woofers. a sub+amp combo will run you less than replacing all your speakers, and youll get a way more dynamic system out of it.
if you do replace your speakers, the front can be replaced by anything, but the rear woofers are 2ohm from the factory. you can run a 4ohm woofer back there without hurting anything, but it will be 3db quieter (which is alot)
Unitronic Stage 1+, 3" DP, Venair TIP, Forge 007, Venair Boost Hoses, Swiss Airbox, "Free Flowing" MAF.
25 psi of fury.
