Aftermarket Headunit Swap - NewBeetle.org Forums
Old 11-19-2007, 02:54 PM
Default Aftermarket Headunit Swap
Ok...first of all, please excuse the newb factor. I'm replacing my 01 Beetle's older Rockford Fosgate deck with a new JVC headunit (KD-PDR30). I've seen several DIY's for replacing the factory headunit that incorporates some special tool from VW. I'm assuming I don't need this if I'm doing an aftermarket swap. Or do I? Which interior console pieces do I remove in order to do the swap? I just don't want to be taking my whole dash apart if I could have just released some magic button and pulled the unit out. Know what I mean?
I hope I didn't underestimate the work. I can always run it by Al & Ed's and see how much they would charge to do it. However, I don't want to throw money away if it only takes 15 minutes.
Old 11-21-2007, 07:11 PM
HaloUmpaLumpa's Avatar
Centerville, IN, USA
Car: 2000 Black GLS 2.0 5-spd
It's a lot easier to swap aftermarket stereos if the first one was put in correctly. You might need some type of key to get the stereo out but the ones that come with your new stereo should be able to do it. You will have to do a little wiring to switch out the adapter plugs to the new stereo but that should be the hardest part of all of this. You shouldn't need to take apart the dash at all to do this.
Check out my MySpace
Say hello to "TS"
Want something to give charactre to your bug, check this out
Wow what a headunit Sharky606 Miscellaneous Hoo-Ha Archive 2 03-04-2007 12:45 PM
Turbo S Monsoon Headunit on eBay SMG Market Place Archives 0 10-18-2006 05:59 AM
? about headunit V-DUBYA Technical Modifications 4 10-04-2006 04:09 AM
CD headunit with aux on the front..what to buy?? theslag Car Audio 3 02-22-2006 05:01 PM
replacing factory headunit jazzcat Car Audio 3 11-16-2005 08:28 PM
