Need to fit a large speaker box - NewBeetle.org Forums
Old 11-27-2007, 05:13 AM
Default Need to fit a large speaker box
How do I pull off the left and right rear plastic trunk panels on my 2000? I'm going to put in a large sub box and I need to see if it can fit in without those in place. Then I can cut into them and scoot the box back in place against the notches.
Thanks
Old 11-27-2007, 05:26 AM
afinley's Avatar
Cold Buggin'
Raleigh, NC, USA
Car: 04 black BTS
hot crackers! how big of a box are you using?
Unitronic Stage 1+, 3" DP, Venair TIP, Forge 007, Venair Boost Hoses, Swiss Airbox, "Free Flowing" MAF.
25 psi of fury.
Old 11-27-2007, 06:14 AM
its one of those 12" Xplods I got from circuit city. It fits side to side perfectly I just need to to scoot it back a few inches but the side plastic panels get in the way cause they round out. Im going to buy some spares and notch them
Old 11-27-2007, 06:39 AM
afinley's Avatar
Cold Buggin'
Raleigh, NC, USA
Car: 04 black BTS
how many 12"s are you using? the trunk is 32" wide.
Old 11-27-2007, 06:51 AM
using 2 12s. The box is 32" wide, its just hitting the corners of the plastic panels towards the rear. I could just build a box that fits, but Im sure this box is tuned to those speakers or at least I hope it is.
Old 12-11-2007, 04:48 PM
Did you already purchase this system or are you thinking about it? I bet you could do much better (sound quality and SPL wise) for the money. Please don't buy that stuff it's horribly over priced.
You should build a custom box that is taylored to the required specs for the subs. It will fit perfect and will sound a million times better.
Old 12-11-2007, 04:52 PM
I'm assuming that this is the box you are talking about?
http://www.circuitcity.com/ssm/Sony-...oductDetail.do
If that's the one then it wont work for you. The box has a port on the left side of the box that needs to have space so air can move in and out.
New Speaker installation BeetleCamry Car Audio 7 12-11-2007 11:55 AM
LARGE New Beetle Banner mentalVdub Market Place Archives 3 04-10-2007 11:18 AM
Monsoon 8 Speaker... so where are they? eltonito Car Audio 3 03-05-2007 02:25 AM
Speaker sound off nagal Car Audio 10 06-05-2006 12:20 AM
speaker sizes?? theslag Car Audio 14 04-25-2006 09:57 PM
