No Bass // Monsoon Amp Issue? - NewBeetle.org Forums
Old 03-28-2008, 08:45 PM
Chucktastic's Avatar
Im bigger than you
Virginia Beach, VA, USA
Car: 2003 Beetle GLS, 2.0L, Auto
Default No Bass // Monsoon Amp Issue?
As the title states at this point I have no bass or to me seems like no 'amp' to my music.
This started about 2 days ago and before that I loved the cars factory audio system and had no plans for upgrading.
Today I had a chance to drive more and it even with the bass cranked to a +9 I get no 'thump' and the music itself seems a little 'tinny'.
Car is 03 GLS with monsoon system and changer in armrest.
Is there a fuse or wire or plug that could have gone bad? Car has been perfect for the 2 weeks I have had it.
Any help would be great. Went to vw dealer today about getting a key made and asked service guy about this and he was kinda clueless.... Figured the best people to ask would be the end users anyways.
Also, where would the factory amp be?
Thanks for any info and the hopeful fast responses
(ps if this is a double post sorry, couldn't find my other thread and I just figured I didn't hit submit at work)
Old 03-28-2008, 09:31 PM
OH, USA
Car: 03 GTI
The amp is behind the rear panel in the trunk to the left. I would think it is likely just a fuse or connection problem, but if your amp has gone bad you can prolly buy one right here from someone who has upgraded.
Old 03-28-2008, 10:11 PM
Im bigger than you
does anyone know where the fuse for the amp might be? Would it be on/in the amp?
I found the amp in the trunk. Stupid me can't figure out how to pull the rear trim piece off that is around the amp(with out just yanking which would just cause more issues lol) so any help on that would be great too.
Old 03-29-2008, 08:03 PM
Im bigger than you
bump for any further help
Old 03-29-2008, 09:40 PM
Picknicker's Avatar
Germany
Car: '99 2.0i
All (aftermarket) Amps I used to have had one fuse (or more) "on" them. Easy to change without opening the amp. The size of the fuse depends on the amp. Aftermarket amps also have a fuse in the power cable...
I don't really know about stock amps - as I had the (cheapest) oem system...
Old 03-29-2008, 10:26 PM
Im bigger than you
yea ive had aftermarket systems in my car before so I know there 'should' be a fuse either there or in the fuse block or under the hood. Check the fuse block on driverside and the fuses under the hood and those look fine.
I just cant figure out how to get the factory amp out of its current location to look and see if it has a fuse or not.
Old 03-30-2008, 07:19 PM
Im bigger than you
bump ....
Old 04-01-2008, 12:36 AM
Im bigger than you
guys/girls/ladies/gentlemen. ANYONE have any further help here? Stereo is killing me! I dont want to take to dealer for something that might a simple fuse or connection....
Also need info on trim panel removal (without distruction) to be able to access the amp directly.
THANKS SOOOOOOOOOOOOOOOOOOO MUCH in advance!
Old 04-02-2008, 10:37 PM
Im bigger than you
SO its still doesnt work. Cant find a fuse in the panel that is blown. Guess I will have to take it to the dealer or local audio shop....
UNLESS.........someone here has more insite? =-)
Old 04-04-2008, 09:17 PM
Im bigger than you
still waiting for a little more help or suggestions on this one...
Got a another problem as of 3am this morning .. third brakelight apparently leaks and during rain set off alarm mutiple times.
Found info on that already and take to dealer on tuesday to have them fix.
Old 04-10-2008, 03:45 AM
Im bigger than you
humm maybe I came up with a new problem?
Still cant find out to remove the rear trim on an 03.. seems almost like a 'rivit'? I will post pics tomorrow or fri
Monsoon woofer issue mattyjo81 Car Audio 2 01-20-2007 07:02 PM
Alarm Issue and Inside Light Issue-HELP! tinarie01 Questions, Issues, Concerns, or Problems with the New Beetle 4 01-02-2007 06:36 AM
Help with adding Bass sub-bug Car Audio 4 08-01-2006 12:42 PM
OE Non-Monsoon Radio Treble/Bass Wierdness! globug01 Car Audio 3 04-28-2006 08:40 PM
Bass Players, where are you? jdesigns Miscellaneous Hoo-Ha Archive 20 11-07-2005 02:06 AM
