Can I use it? - NewBeetle.org Forums
Old 05-28-2008, 11:45 PM
HeatherBug's Avatar
bored at work...
Texarkana, TX, USA
Car: *~Candie~* '03 White 1.8T
Default Can I use it?
http://cgi.ebay.com/ebaymotors/VW-BE...ayphotohosting
Would I be able to use this in my 03 Beetle? He mentions that he doesn't provide the plugs so would mine work?
♥♥ Candie ♥♥♥
Old 05-29-2008, 01:45 AM
Albuquerque, NM, USA
Car: 2003 GL TDI
Yes, pull the plugs out of yours and plug them into this one and it will work fine, assuming
1. it's a good, working radio
2. seller provides the code.
3. Seller should have stated whether this is Monsoon or non-Monsoon radio. The radio in the photo IS NOT and if you currently have a Monsoon radio, you'll likely be disappointed. It's all just easier to replace yours with the same kind in this regard.
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
