Simple Aftermarket CD Player Question - NewBeetle.org Forums
Old 07-20-2008, 04:38 PM
Default Simple Aftermarket CD Player Question
Ok,
2001 beetle with a tape deck am/fm radio, doesnt say monsoon anywhere, no CD changer in trunk.
I have a pioneer deh-2000mp H/U. and the wiring adapter and antenna adapter, and the neccesary VW removal keys.
Is this just a wire up, and plug in job>? Or am I missing something .. will it screw up diagnostics, etc etc
i keep reading a lot of problems.
I just want a CD player in this car!!
tips/help appreciated! doing it in about 1hr.
Thanks
Old 07-20-2008, 04:55 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
on the power wires section of the harness, i think it's the black one, but i might be wrong, make sure you only have the constant 12v, switched 12v, and ground hooked up to it.
All those other wires are for the diagnostic system and should never be plugged into an aftermarket radio.
When you pull out the radio, there will be a diagram on it telling you the pinout. just make sure it matches the harness you have.
other than that,s it's pretty plug and play. if you have a powered antenna adapter, hook up your power antenna lead to that, and not to the car's harness.
Old 07-20-2008, 04:58 PM
the antenna is not power on this car, it is stationary
anddd
I have a harness u plug into the factory harness, then splice the H/u harness to the harness i bought... like most installs Ive done... just dont wana cause any problems, just want the player to work!
what do u think?
Old 07-20-2008, 05:18 PM
Toad's Avatar
Mableton, GA, USA
yup. it's pretty easy. just make sure you don't plug anything into the diag wires if the harness you bought has leads going to them.
Stock Vw Tape Player To Later Vw Cd Player Upgrade Question??? Help!!!!!!!!!!!!! chris22104 Car Audio 1 07-20-2007 05:06 PM
Aftermarket CD player suggestions? xlifeguardx Car Audio 20 02-15-2007 09:49 AM
Pic Request - Aftermarket CD player installs Jamel Car Audio 37 10-06-2006 03:20 AM
A simple question about the water temp indicator kevin_k Questions, Issues, Concerns, or Problems with the New Beetle 11 03-31-2006 12:50 PM
Simple Aux In Question ryanbutterworth Car Audio 3 11-13-2005 01:15 PM
