Rear-fill is no good, let’s use the space for something else:
Raammat, then Ensolite: Then take these: And you get this: Final resting place: The amp is an a/d/s/ 630x, 6 channel, running active and powering the whole system. Last edited by PLAN_B; 08-08-2010 at 11:56 PM.. Reason: correction |
Alpine XT19 ring radiators quickly installed off-axis just to get by:
Black Ultrasuede on dash panels to help with tweeter reflections: Deflex panels behind mids: Mids from an MB Quart 218.61 Q set: To decouple: driver>ensolite>ring 1>ensolite>ring 2>ensolite>door panel. Good midbass without a single resonance! And bringing up the rear, an Image Dynamics IDQ10 in a .5 cu ft sealed enclosure; I love this sub! Last edited by PLAN_B; 07-24-2008 at 05:57 AM.. |
Very nice!!!
Cyber Green. It's not a color. It's a way of life. '00 GLX Cyber Green / Cream, 5sp. (Click for pics!) '07 Audi A3 S-Line |
Thanks for the compliments! Actually, despite the Phoenix heat, the amp doesn't overheat no matter what I ask of it. Although I am considering installing an ultra quiet cpu fan to pull air in the speaker grill and out to the trunk/hatch just for piece of mind and amp longevity. A/D/S amps are pretty bulletproof though, so I'm not worried.
My only other plans are to put a fiberglass enclosure for a 10" shallow sub behind the passenger side panel. Then the entire system will take up zero usable space! |
There's about 2 inches of depth from the panel they're screwed into to the outside panel of the car so it won't take too much precision. Overall there's about 4.5" max usable depth so it's not too hard to fit an amp back there; the problem is finding one with the right height and width dimensions because of the wheel well. I looked at A/D/S amps because I knew they made a lot of multi-channel old school amps that had simple, effective verticle heatsinks that allow the air to circulate even when placed as I have it. To anyone considering installing an amp like this: I'd recommend looking for one with a similar heatsink design unless you plan to use a fan. |
![]() It's a 2" Aurasound driver that has usuable frequency response from about 200hz to 10,000hz; just about perfect for a surround speaker. For now though, no rears. As I mentioned, the passenger side will have a sub in it at some point. I'm anxious for that, but don't have any time to do anything about it right now. Last edited by PLAN_B; 08-07-2008 at 02:40 AM.. |
| pics from cheap FMIC install | green02turbo | 1.8 Liter Turbo | 2 | 06-20-2008 07:17 AM |
| NE1 have pics of spkr install? | apodaca | Car Audio | 22 | 10-20-2007 12:04 AM |
| Greddy FMI. install pics. | speedsk8er | Technical Modifications | 8 | 03-25-2007 08:49 PM |
| Aftermarket deck install..... pics, smooth mount | OldSkoolVWLover | Car Audio | 2 | 12-21-2006 07:15 PM |
| beetle pics link before suspension install | degny21 | Technical Modifications | 0 | 01-05-2006 05:20 AM |
