Radio Wiring Troubles!! - NewBeetle.org Forums
Old 08-08-2008, 04:50 PM
Exclamation Radio Wiring Troubles!!
Hey everybody. Ive got some wiring troubles. I have a 2002 1.8T Beetle and my radio died. It was aftermarket. I installed a new one and still dead. I have checked under hood links etc and the fuse panel. All good. Breaker/fuse on back of head unit intact. I guess my question is this.
Is there a in-line fuse behind the dash somewhere that I am not aware of? When the radio died, I believe I heard a small pop noise from inside somewhere.
Any help would be GREATLY appreciated.
P.S. Either the previous owner was cheap and lazy or the radio was previously stolen as I have no factory wiring terminals to hook to. All hacked off but it worked for a long time as was just another factoid for consideration.
Old 08-08-2008, 05:18 PM
jackfrost's Avatar
and your little dog too!!
Gurnee, IL, USA
Car: 2000 Cool White glx
moved here, you should get better response here
Rest in peace rich, no one will ever forget you. fo' shizzle mate......fo' shizzle
quicker than quick, faster than fast i am...wtf, im on fire AAAAAAACK
Old 08-21-2008, 02:48 AM
vwtazzman's Avatar
Step,drag,stumble-drool
Bakersfield, CA, USA
Car: '02 Turbo-S
Question fuse problem.
In my "Haynes" Book it shows two fuses for the audio system.....
Fuse #37-10amp hot with key in ignition. it's Brown/Red
Fuse #42-25amp hot all the time. it's Red/White
The ground is the Brown wire.
Hope this helps and good luck.
Help Please! Wiring questions for a radio on a 1999 bxtech Car Audio 3 05-22-2008 07:11 PM
Question about proper radio wiring amishman Car Audio 0 11-13-2007 02:54 AM
Radio swop,wiring color fro rasio bug_n_67 Technical Modifications 0 01-07-2007 06:47 AM
Engine Troubles jklassen 2.0 Liter Gas 2 11-01-2006 07:47 PM
Need Wiring Diagram for 2005 Radio VelvetFoot Car Audio 7 10-24-2005 01:56 AM
