monsson install question - NewBeetle.org Forums
Old 08-21-2008, 03:23 PM
mrsbeazley's Avatar
riverside ri , RI, USA
Car: 2002 beetle 2.0 gls
Default monsson install question
i bought a new monsoon ( to replace the existing one) is it fairly easy to do ?
my bra must fit correctly or my headlights will look bad .... beazley
Old 08-22-2008, 12:59 AM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
It should just plug right in.
Old 08-22-2008, 03:05 AM
vwtazzman's Avatar
Step,drag,stumble-drool
Bakersfield, CA, USA
Car: '02 Turbo-S
I just did it last weekend and it was fairly straight forward. Just be patient with the two bigger plugs as you get just enough wire slack to get your finger tips on the release catches.
Good Luck!
p.s. get the right removal "keys"...life will be much easier.
Old 08-22-2008, 06:34 AM
macdave's Avatar
Olympia, WA, USA
You can make it easier by removing the switch panel below the console. I think there are 4 screws holding it on. With it removed you can reach behind the radio and push the wires up so there is more slack.
Old 08-22-2008, 02:43 PM
mrsbeazley's Avatar
thanks - ill get the keys and try it this weekend
Old 08-22-2008, 04:58 PM
Albuquerque, NM, USA
Car: 2003 GL TDI
Radio from a 2006 or newer, i.e. canbus system, will fit and connect, but it won't work very well in an earlier car.
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
MBC DIY install TurboS-CR 1.8 Liter Turbo 19 06-03-2008 03:31 AM
Install Help draco24433 2.0 Liter Gas 9 05-03-2007 02:17 AM
caractere rear spoiler install question JohnnyJet Styling Modifications 2 02-16-2007 06:34 PM
Pic's of a spare tire well sub install and Kick pannel speaker install Holland Car Audio 10 12-26-2006 04:19 AM
p 0411 code question and coolant leak question.... bobbittle 1.8 Liter Turbo 5 06-12-2006 02:47 PM
