cd player dead--fuses keep blowing - NewBeetle.org Forums
Old 08-30-2008, 08:08 PM
Unhappy cd player dead--fuses keep blowing
we just bought a 2000 gls, and when we got it, the stereo was dead, i checked the fuse box, and both the stereo fuses were blown, when i put in the 25 amp hot fuse, it right away sparks and blows in my hand, and the 10 amp blows as soon as ignition power is sent...any ideas??
Old 08-31-2008, 03:21 PM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
I mean, for real?
YOU HAVE A SHORT.
Find/fix the shorted-out wire before you go any further... before you burn your car up...
Start by tracing wires back from the load end to the accessory, this means every inch of wire. Pay close attention to junctions and wire pass-throughs, that's usually where you'll find compromised wire insulation. But until you do this, you can't even begin to think about replacing the fuses...
Old 09-05-2008, 03:33 AM
langheldphoto's Avatar
Britt
Petal, MS, USA
Car: 2001 20v turbo
Default ,
if it is an aftermarket radio more than likely someone botched the wiring behind the radio.
that would be the first place to start looking.
Old 09-10-2008, 02:32 AM
NaplesTurboS's Avatar
VW Turbo S
Naples, FL, USA
Car: 2002 Turbo S
Default In The Same boat...
My Turbo S Beetle is the same way. I turned a corner and the stereo just shut off and it is an aftermarket radio, but one problem. How do you get it out. I bought it with the radio with the car and got it used.
Jon
Jon
Washer keeps blowing fuse Pdub Questions, Issues, Concerns, or Problems with the New Beetle 3 12-19-2007 09:05 PM
Stock Vw Tape Player To Later Vw Cd Player Upgrade Question??? Help!!!!!!!!!!!!! chris22104 Car Audio 1 07-20-2007 05:06 PM
radio keeps blowing fuse?? help karynna Questions, Issues, Concerns, or Problems with the New Beetle 2 10-11-2006 03:05 AM
Blowing smoke at a tailgater!! CoriBug The New Beetle Experience 26 06-21-2006 07:07 PM
Thoughts on Blowing Co2 on intercooler green02turbo 1.8 Liter Turbo 4 06-19-2006 03:16 AM
