I recently bought a used 2000 Beetle (TDI - stick) with an OE radio.
While the CD player and the cassette deck work great, AM/FM reception does not work, since I bought the car. The AM/FM display works. I can only hear minor noise out of the speakers (engine off, radio full loudness) and suspect an antenna problem. The antenna is connected to the radio, I checked. I read in another thread the antenna has an amp. Where would I find the antenna amp in the car? Are there any known field problems with AM/FM radio reception? How to R&R the antenna? Thanks for every response. |
Do a search of 'antenna' in this forum (car audio) and you will come up with a lot of threads on this subject. You may find this one quite interesting: http://www.newbeetle.org/forums/show...hlight=antenna
From
http://www.ebooksquad.com/2008/08/18...-bulletin.html Volkswagen AM Radio, Poor Reception Technical Service Bulletin Content Inside : This service bulletin is dedicated for New Golf, New Jetta, New Beetle, Passat. Condition : AM reception is poor. May be caused by: An incorrect antenna mast installed for the antenna base equipped with the vehicle Poor ground at the antenna base or radio Poor battery ground to chassis or engine Poor antenna cable connection at Radio Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. Note: Mismatched antenna mast and base will cause poor AM radio reception. If antenna mast matches the antenna base correctly: Check antenna coaxial cable connections arrows for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). Check ground at the antenna below roof Nut 4 (torque = 7+1 Nm) must firmly secure antenna to roof). |
| Horrible AM reception with OEM radio | J Tinsby | Car Audio | 5 | 08-16-2008 11:14 AM |
| Radio factory radio from new beetle 1998 and newer $70 | turbobugger | New Beetle Classifieds | 1 | 08-06-2008 12:41 AM |
| Crappy FM and AM radio reception... | jiggseob | Car Audio | 5 | 07-29-2008 11:57 PM |
| FM Reception | liam51 | New Beetle Convertible | 7 | 06-16-2007 11:53 AM |
| How is the reception of this atenna? | 2.5beetle | Styling Modifications | 6 | 08-18-2006 09:39 PM |
