Hello Everyone,
I have had two aftermarket stereos installed in a 2004 beetle. Both have had the same problem... The stereos work fine and have all the functionality you would expect. However, once the car is turned off, the stereo loses all memory of stations/settings. I have checked the fuses and have not found a problem there. Any help anyone could give on this problem would be greatly appreciated! TMCinDC |
Rich,
Thanks for the info...I appreciate it! Are the two fuse holders just to the left of the driver in the door area? If that is not the problem, then I assume that if the stereo is wired to the "always on" wire then that would fix my problem, correct? I'm sorry, I'm new with this and not very handy. If you could just clarify this for me I would be very greatful. TMCinDC |
Aftermarket stereos have in-line fuse holders. You will need to trace the wires from the stereo back to the power source where you should find a 2 small plastic holders inserted in the wires. Inside the holders you will find a fuse. A competent installer would have placed them near the power source so they would be under the panels of the dash by the door.
| Aftermarket Car Stereo/XM Install Issue | rabbitdog | Car Audio | 0 | 12-27-2008 05:29 PM |
| Could an aftermarket stereo affect your throttle body? | Anaconda | Car Audio | 5 | 04-26-2008 08:45 PM |
| HeLp....aftermarket stereo and airbag light | kittinbeetle | Car Audio | 2 | 10-30-2007 08:06 PM |
| FS: Aftermarket stereo install parts | Woz2000 | Market Place Archives | 4 | 07-02-2007 04:43 PM |
| will aftermarket stereo be able to control factory CD changer? | ppp_369 | Car Audio | 1 | 10-17-2006 06:57 PM |
