Radio Oddity
So here's an interesting one...
Tonight I get in my car to go home, radio off. I push the volume knob in, radio comes on, but it is super loud and will not turn down anymore. It was just fine earlier today, but tonight its like it's stuck on loud... Also, when I turn it on, it doesn't say MONSOON on the display, it just goes straight to CD x trk x or whatever. It won't turn off either... You push the knob in and it stays on until you push the knob again (ie turning it back on) then it turns off and you can put the knob in (ie like it should be when powered off...) I've tried restarting the car; everything, but nothing seems to make it work like normal... Any suggestions? Do you think pulling the fuse would make it reset or something, but then I would need the code, right? ay ay ay... so strange!
any takers on this one?
thanks a million,
jake.
EDIT: It is a stock monsoon head unit that came with the car and has the 6 disc changer in the arm rest.
would super cold weather affect performance at all? i wanna say this happened to me one other time, but simply turning the radio on and off once fixed the problem...
