Changing door speakers, can someone look at these pics please ? - NewBeetle.org Forums
Old 02-01-2009, 10:43 AM
Bristol, UK, England, United Kingdom
Car: Boxster - soon to change tho.
Default Changing door speakers, can someone look at these pics please ?
Ok, I've taken the door panel off, and this is what I have :
Now, the speaker adapter I have is this :
Which doesnt fit into the bit that was in the door :
It just sits against those legs, meaning that the speaker ends up sitting higher than the rubber surround, meaning if I put the door panel back on, it would be up against the speaker and not the rubber surround :
I'm guessing it's because the bit that was in the door, that I've been trying to fit the speaker adapter to, is not actually the real part that was meant to be there and has at some point been replaced by a cowboy?
The speaker I took out had been screwed in with self tapping screws, so that's a worrying starting point.
Any suggestions anyone ?
Old 02-01-2009, 11:10 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Should be fine. My Fosgate FanQs are being held in with self tapping screws as they did not fit the factory bracket for the fronts and rears.
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
Old 02-01-2009, 12:00 PM
What do you mean, should be fine?
I cant get my new speakers to fit, thats not fine?
They fit into the adapters/spacers ok, but then the spacers wont fit in anywhere.
Old 02-01-2009, 12:23 PM
20V GTRS
My bad, I was viewing the question as about the screws.
Will your speakers fit without the spacers or do they bottom out?
Old 02-01-2009, 03:18 PM
Theyre too small for the hole in the door.
From the left hole to the right hole in the door is 21cm.
From the left hole to the right hole in the speaker is 16cm.
I thought that was what the adapter was for, that it would fit into the 21cm hole and leave me the holes 16cm apart for the speakers.
Confused.
Old 02-01-2009, 04:14 PM
20V GTRS
Sounds like you may have to modify the adapter that came with the speaker or make one from scratch.
Old 02-01-2009, 05:05 PM
Yeh, in the end I've cut all the lugs out of the inside of the existing surround, and sank the new adapter into it and glued it.
I'm gonna write a small guide once done for people with the new shape beetle as it seems all the info flying around is wrong for that shape.
Old 02-01-2009, 10:40 PM
Adelaide, South Australia, Australia
Car: 2000 NB 2.0L Auto
Dubster, do you have a pic of your door with the existing plastic removed?
IMO the adaptor you got would most likely be designed to replace whatever rubber/plastic is already there.
At least the adaptor I bought recently was designed that way.
Old 02-02-2009, 05:47 AM
No, I can take one though, and will do before I put it back together.
Let me guess though - you have the older shape new beetle?
I've got the later shape, and I think what they've done is make the holes considerably bigger on the newer shape, even though the adapters state they will fit 2006+
Old 02-02-2009, 10:15 PM
Ahh yes - 2000 NB here
I have my door speakers mounted now, next challenge is where to place the crossover and mounting the tweeters in the A pillars.
I still have stock speakers in the rear and they sound pretty rubbish compared to the new ones I got on the weekend.
No Sound Out of Both Door Speakers _goREDgo_ Car Audio 1 09-16-2008 03:42 AM
WTB - Monsoon Door Speakers lebicicletta Car Audio 2 12-25-2007 07:16 AM
Please help....both front door speakers went out mooshi Car Audio 1 07-16-2007 01:05 AM
My vectra from the UK (loads of pics pics) swankey Photos: Other Rides 5 03-29-2006 03:13 PM
changing speakers slugbug123 Car Audio 1 09-27-2005 02:58 PM
