If it was the right channel that was fuzzy the most, then the wires are crossed, touching, or touching metal on that side, which wil cause the channel to buzz out, and also cause all the other speakers in the set to buzz and make horrible noises. If both sides make noise, and you made absolutely sure that the wire connections aren't touching, it means you need to run new wires from the head unit to the speakers, which is a little more of a pain, but the speakers aren't broken, relax.
Keep in mind this is monsoon, so I think that the issue lies in the wiring between the amp and the speaker. The glitching is not noticeable in any other speaker while it is affecting the passenger side door driver.
I guess what I am asking is: is there a known defect in the amp/wiring or otherwise that could cause this? |
"You can also open your trunk and pull back the cover over the spare and look toward the left rear tail light (you need to stand on your head and look. If you see a small black box (about 7x6 or so), then that is the Monsoon amp. Check the wiring there because its possible the speaker wire has come loose there. "
| Drivers door lock | Skoobahead | 2.0 Liter Gas | 3 | 01-24-2009 04:10 AM |
| Drivers door lock cylinder pops away from door | redbug119 | 2.0 Liter Gas | 1 | 01-23-2008 01:34 AM |
| WTB: 03 turbo S Monsoon driver door woofer | pueblorrado | Parts and Accessories | 1 | 11-13-2007 06:21 PM |
| Drivers door handle | Willard | 1.9 Liter TDI | 2 | 07-04-2007 04:04 AM |
| FS: Front Drivers Side Turn Signal | FallinApartBoy | Market Place Archives | 0 | 01-30-2007 04:24 PM |
