Code reader and factory radio - NewBeetle.org Forums
Old 03-21-2009, 11:36 PM
Default Code reader and factory radio
Hi,
I was told that DTC codes could not be read by any code reader if the factory radio has been removed and replaced with an aftermarket radio.
Is this true?
Do I have to reinstall the factory radio to read the check engine codes?
Thank you,
Old 03-22-2009, 12:00 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Go to the VAG COM website and read what they have to say.
http://www.ross-tech.com/vag-com/aftermarket-radio.html
It has to do with there being power on a wire that VAG COM is not expecting to be powered.
I don't know about regular code readers.
Old 03-22-2009, 12:58 AM
cep,
I read thru the link you provided. I now understand the possible problem. I will used my volt meter to check between pins 4-7.
Thank you for the detailed answer
Code reader just for VW Punchbuggybluenoreturns!! Questions, Issues, Concerns, or Problems with the New Beetle 2 01-24-2009 11:24 PM
odb2 code reader cruzzzn Questions, Issues, Concerns, or Problems with the New Beetle 4 12-29-2008 11:40 AM
code reader BMyers Questions, Issues, Concerns, or Problems with the New Beetle 4 07-28-2008 02:31 AM
FS:OBD II Code Reader (non-VAG-COM) boblamb58 Parts and Accessories 17 01-14-2008 01:01 PM
Portable DTC code reader. aeholton 2.0 Liter Gas 1 12-08-2007 02:30 AM
