No Power to Stereo - NewBeetle.org Forums
Old 04-03-2009, 04:47 PM
DNAROCKS!'s Avatar
Default No Power to Stereo
Just bought 2003 beetle. There seems to be no power to the stereo or lights in the ac/heater dials? Any suggestions?
Peace Out!
Old 04-04-2009, 02:33 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Default Gremlin
Fuses are a good start. If you find one burned out and replace it and it burns out again there's likely another issue.
Questions:
Did you buy it from a lot or private party?
If you bought it from a private party did they have an aftermarket stereo but replace it with the stock before they sold it to you?
SoCalnewbeetleclub
Old 04-04-2009, 03:14 PM
BUGSTUFF's Avatar
New Beetle Accessories
Bartlett, IL, USA
For the radio - if the fuses in the fuse block are ok, there is a fuse on the back of the radio that may have blown. You'll have to pull it to check that fuse.
The heat/AC controls have a single bulb that is located behind the blower knob. Instructions can be found here:
Do Your AC/Heat/Fan HVAC Controls Light Up?
Be very careful pulling the knob out (Make sure it is in the #2 position - straight up-and-down) or you can mess up the switch assembly.
Kirk & Pam & "Key Lime"
Northeast IL VW Association
Volkswagen Club of America
Expert advice? 06 monsoon cd stereo hook ok where had 02 monsoon casette stereo? AuctionHugh Car Audio 9 11-06-2007 10:28 PM
HELP! Can't get stereo out. Snuguza Car Audio 7 03-31-2007 10:00 PM
stereo Lezliej Styling Modifications 3 07-16-2006 07:02 PM
Stereo kdbug Technical Modifications 9 07-13-2006 04:14 AM
Stereo Not Getting Power sdmcdowell05 Car Audio 4 04-08-2006 05:28 AM
