Convertible rear speaker question - NewBeetle.org Forums
Old 06-25-2009, 02:45 AM
slidell, LA, USA
Default Convertible rear speaker question
I am trying to access the rear speakers in my 04 convertible all I seem to be able to find are instructions for hard top cars can anyone tell me if there is a difference in removing the pannels? If there is a difference how do I go about removing the pannels?
Old 06-25-2009, 10:22 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
This is one you just may need access to the Bentley manual. The CD version I have won't let met cut and paste. You will need to remove the seat back and cushion to gain access to the panel bolts at upper rear corner. Several clips around edges and lift up to remove. Procedure varies depending on top and flaps, depends on year model.
I know this is brief and not very clear, but the best I can do. Search the org for additional help perhaps.
Tom
Old 06-25-2009, 11:50 AM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
Here you go, my friend:
Video - VW Technical Service Training - New Beetle Convertible - Rear Side Window Removal
Have fun, and good luck!
Old 06-25-2009, 12:16 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
That video makes it look easy to do. I knew someone would have a good answer.
Old 06-25-2009, 01:47 PM
slidell, LA, USA
Thanks for the help guys I will give it a go when I get off of work.
Non-Monsoon component speaker question - answered! SinisterP Car Audio 2 06-02-2010 07:11 PM
rear speaker removal? low_k3y Car Audio 6 03-06-2009 03:22 PM
rear speaker replacement, non-monsoon zinzig Car Audio 2 02-13-2009 04:05 PM
Rear Speaker Install Rickyburton2159 Car Audio 1 09-10-2008 01:36 AM
Rear Speaker Removal Help Tacoma Car Audio 4 08-26-2006 07:05 PM
