Originally Posted by Justy Gabby
I've got a 2005 beetle coupe that has the factory mp3 CD radio. When ever I turn off the car or the radio I get a loud pop noise. Anyone know what's causing it?
There should be a mute circuit inside the radio that is supposed to prevent the speakers from popping when turned on or off. I would start with the radio and see if there is any corrosion on the left side bottom of the circuit board where the audio chips are located and near the power connector.
You didn't say if you had a Monsoon System or not.
The Monsoon system has an amplifier along with the radio, but I had no interaction with those as they were a disposable item for VW dealers. It's possible it might be bad also.
