where is......... - NewBeetle.org Forums
Old 08-21-2009, 09:02 PM
Grandmaster B's Avatar
dallas, TX, USA
Car: 01 TDI beetle
Default where is.........
That factory Amplifier, i have a 00 new beetle tdi, i put an aftermarket stereo in with the proper plug adapter, and some aftermarket door speakers,driver side speaker is not workin switched sides it's not the speakers, also all the speaker wires in the doors and rear are the same colors orange/green red and green, I looked at the plug thinkin the orange/green was the neg on both sides, now im not sure I checked the drivers side the orange is hot wtf??? need help asap gotta put the wifes car back together today!
63 custom bug,67 custom square,58 custom ghia,01 TDI beetle www.aricoolers.org
Old 08-21-2009, 09:07 PM
dallas, TX, USA
Car: 01 TDI beetle
and i dont think its a monsoon it doesn't say it on the old deck
Old 08-21-2009, 11:21 PM
Oldbugman's Avatar
Jacksonville, FL, USA
Car: 2000 GLX 1.8T 5 SP
Easy check to find out which lead is positive, connect volt meter to both speaker wires, if you get the - symbol on your voltage reading you are reversed on your voltage, reading should look something like this. 015 V not - 015V. of course I'm sure you already know this but it's a simple check.
Old 08-21-2009, 11:51 PM
Yello_jellybean's Avatar
Can you handle it??
Denver, CO, USA
Car: 2005 Platinum Grey TDI GLS /DSG
To be honest with you, I don't think, (I could be wrong)that if you do NOT have a Monsoon stereo system in your car stock, That the regular stock stereo system in the NB has ANY type of amp in it. Some previous owner or something could have installed one, but I am pretty sure it did not come that way.
I would also think that if there was an aftermarket amp installed in the car, they would have switched out the deck too though. Why would you put an aftermarket amp in a car that has a stock stereo?
Only a Monsoon stereo came stock from VW with amplifiers.
Old 08-22-2009, 12:39 AM
HarlequinPixie's Avatar
ElectricHarleyHouseOfLove
Currently: Williamsburg, VA, USA
Car: 2001 Batik Blue 2.0 GLS 5spd
Yeah. Monsoon setups have a seperate amplifier, but the non-monsoon ones are just built into the head unit.
i would imatine you probably got a bit of wiring goin out on ya :-/
Old 08-24-2009, 11:22 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
if you have monsoon, it'd be in the left side of the trunk behind the trim panel. pull out the piece that you would remove to change the tail light and you should see it.
do you have tweeters in the dash or the door? monsoon had 'em up top, base stereo was in the door.
Old 08-25-2009, 04:34 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
See this link for pics...
What are the locations of satellite and monsoon boxes?
marvins_dad ~ antoine
