replacing factory cd play for an ipod controled one - NewBeetle.org Forums
Old 09-06-2009, 08:23 AM
bugatron's Avatar
Boosted Bug
Townsville, QLD, Australia
Car: 02 Turbo yellow Beetle
Default replacing factory cd play for an ipod controled one
just wondering how i would go about replacing the factory cd player with one that controls my ipod? do i need a certin tool to remove the cd player? also will i need an after market facia to fill the gabs? where do i start?
Old 09-06-2009, 03:17 PM
wasilla, AK, USA
Car: 1999 new beetle. 2 liter
ill be honest...if you know that little about car stereos id start by just taking it to a stereo shop or even best buy.
this isnt the easiest car to do an install on, and it could be very difficult for someone with little understanding.
u do need keys to remove the factory radio. althou many times when pulling out the radio the radio harnesses dont like to slide out of the dash very easily. obviously the factory radio is much wider than an aftermarket radio. so you need a dash trim kit. i suggest metra. ud also want a wiring harness that connects to the original radio harnesses.
what year is your car....its important to know...because you may have an issue with what many people refer to as the k wire.
also do you just have a regular system or the premium.
log onto metraonline.com and it will walk you thru the stuff youll need
u should also need an antennae adapter.
also if you decide to tackle this install yourself...remember once you disconnect the factory radio..to put it back(if you for some reason have to) you need to have the radio code...which used to be on a card in your owners manual.
there are many tutorials on how to do this install on this forum.
so you can definetly try it...but in my honest opinion... id have a professional do it. someone that warantees their workmanship.
im quite sure others will concur with my feelings...but if we can help...let us know...
just know that its not as easy as most cars...
also keep in mind that without cutting pieces of the interior of the dash...there are some brands of radios that just wont fit in the car. brands like dual and jensen are usually very deep. if your looking for something to control your ipod well id suggest pioneer, kenwood, or alpine.....each have their benefits and downpoints thou...if your curious i can get into that more...
good luck
Old 09-06-2009, 03:23 PM
norcalturbobug's Avatar
the world famous
antioch, CA, USA
Car: 2000 GLX turbo
Talking ipod adapter
there are a bunch of ipod adapters that use the stock stereo. take at look at these..
Volkswagen New Beetle iPod to Car Interface Adapters for Volkswagen EnfigCarStereo.com iPod XM Sirius car interface adapter kit specialists.
i recall the immortal words of Socrates....i drank what?
Old 09-07-2009, 12:02 AM
Charlottesville, VA, USA
Car: 2001 New Beetle
if you are interested in using an ipod adapter, then I have one for sale that will charge you ipod and play it through the cd changer port. You then use your ipod to control your music. It is extremely simple to install I can walk you through it. $59 shipped to you. Its in new condition.
cheers, Tim
Old 09-07-2009, 10:24 AM
bugatron's Avatar
Boosted Bug
thanks fellas i was thinking of an after market cd play for the use of the ipod and for later on when i want a sub and amps for the speakers.
not sure what i have regular system or the premium, its what ever is standard in the car from factory so not sure
FS: Drive N Play 2 iPod integration... Caractere Parts and Accessories 0 02-19-2008 01:25 AM
Factory Ipod adapter CYBERGREENCC Car Audio 3 12-21-2006 03:54 PM
iPod and Harmon Kardon Drive+Play heeeheee Car Audio 1 05-08-2006 03:48 PM
FS: ipod adapter for factory HU miciam Market Place Archives 6 03-08-2006 11:46 PM
replacing factory headunit jazzcat Car Audio 3 11-16-2005 08:28 PM
