Hi All,
Just wondered if someone could clarify something for me, I installed an aftermarket stereo with the kit from ebay below Everything was fine until the car went to the menders and they tried to pull the codes but couldn't - they said that it was the after market wiring harness and printed out the instructions from Ross Tech for me below. Ross-Tech: VAG-COM: Afterrmarket Radio Problem The thing is that the Ross tech instructions say that that pin 3 should be looped back into the harness (and the mine has pin 3 looped to pin 5) is that right? I can't figure out what looped back to the harness means? Obviously there is a problem with the harness (and I should email the guy that I bought it from above) but I would like to figure what this is! Cheers, paul Pictures of the Ross Tech pins and the after market harness below.
2006 Red MK5 GTI - DSG, Leather, Sunroof, Sat Nav, Xenons || Sold! 2002 Turbo New Beetle
He Ross-tech instructions refer to the K-line wire coming from the harness into the plug, this needs to be removed from the plug (pin 3?) and taped back to the wiring harness to isolate it from the stereo plug.
The harm though is caused by the loop of wire so cutting that and taping both ends (One carries 12V and the other will be the K-line signal) so both need to be safely isolated if you go that route.
Cheers Simon |
| Aftermarket Stereo | a_happier_me | Car Audio | 4 | 05-24-2009 04:40 PM |
| Lose Memory on Aftermarket Stereo... | TMCinDC | Car Audio | 4 | 12-29-2008 03:26 PM |
| Aftermarket Car Stereo/XM Install Issue | rabbitdog | Car Audio | 0 | 12-27-2008 05:29 PM |
| HeLp....aftermarket stereo and airbag light | kittinbeetle | Car Audio | 2 | 10-30-2007 08:06 PM |
| FS: Aftermarket stereo install parts | Woz2000 | Market Place Archives | 4 | 07-02-2007 04:43 PM |
