Stero Won't Come Out - NewBeetle.org Forums
Old 11-04-2009, 05:10 PM
Default Stero Won't Come Out
I'm trying to remove the stero from a 2000 GLX. I purchased the DIN keys from a parts store, but cannot get the keys to "click" in the slots.
Any suggestions?
Old 11-04-2009, 08:37 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
This is ten times easier if you have had a chance to see how the catches on the stereo work, basically you are trying to put the fine end of the key into a slot in a spring loaded blade and move the blade towards the centre of the stereo unit to disengage it from the stereo surround. You can work on one side at a time, the stereo will move fwd 1-2mm when the catch is released, then you can do the other side....
Cheers
Simon
Old 11-08-2009, 06:50 PM
Charlottesville, VA, USA
Car: 2001 New Beetle
stick the keys in and pull like crazy on the tape deck opening
cheers, Tim
cant get origenal stero out - even with proper keys !!! jamieandthemagictorch Car Audio 13 01-31-2007 08:17 AM
