CD Changer Harness - NewBeetle.org Forums
Old 01-09-2006, 03:34 PM
slugo's Avatar
Phoenix, AZ, USA
Car: YELLOW 2000 1.8
Default CD Changer Harness
I have a question about the harness for the cd changer on a 2003 beetle. The cd changer harness is in the console, and I would like to mount a changer in the trunk, is there anyone that makes a harness to plug into the center console that would extend to the rear trunk area?
"Experience is what you get when you don't get what you wanted"
Old 01-09-2006, 11:13 PM
Blue Thunder's Avatar
Quintuple Dubness
San Marcos, CA, USA
Car: '00 Cybergreen GLS '03 BLCC 1.8t
Yeah VW has the part but it is $103.20 it is in the driver gear book as an accessory to the phatbox. Part number 1J0051592A
http://drivergear.vw.com/store/searc...word=phatnoise
For 2003.5's and Verts. I basically made one by splicing the cable to make it longer.
Webmaster Southern California New Beetle Club
Http://www.socalnbc.org
One of the rare 5 New Beetle families out there
Old 01-10-2006, 12:05 AM
Steinola's Avatar
Portland, OR, USA
That cable actually hooks into the rear of the headunit. Slugo and I have already discussed that one.
What he's after is a cable that hooks up to the existing CD changer cable in the center console.
I left pretty detailed instructions on how to make one yourself, Slugo. As far as I know, that's the only way to do it. I doubt any after-market companies would be terribly interested in pre-building them for the market.
Old 01-10-2006, 01:48 PM
slugo's Avatar
Phoenix, AZ, USA
Any problems with slpicing the harness? Did you slpice or use some other type of connection?
thanks
slugo
Old 01-10-2006, 04:53 PM
Quintuple Dubness
San Marcos, CA, USA
I cut the connector from under the center console off leaving a few inches on connector(color code will guide you in reconnecting) and spliced wires of equivalent size on to the connector. Then connected a female molex connector (available at Radio Shack) to the wire ends then spliced and soldered wires to the cutoff connector and attached male molex to those. Ran wires under carpet and back seat to the console under drivers seat. An alternate method would be to splice from CD changer end connector instead. Just be sure to use the same or larger wires and insulate them well. I had no problems and saved maybe $95
Find my CD changer harness plug thingy jpdeuce Car Audio 5 12-28-2005 05:03 PM
Wtb:oem Cd Changer 1beetle Market Place Archives 5 11-15-2005 01:38 AM
wire harness problem angelusnhc Car Audio 3 11-03-2005 11:54 PM
FS: KILLER SWAP - R32 Engine Assembly with harness and ECU BVA Market Place Archives 2 10-31-2005 02:49 AM
wire harness angelusnhc Car Audio 7 10-15-2005 06:09 AM
