radio and ignition - NewBeetle.org Forums
Old 01-14-2010, 09:33 PM
Default radio and ignition
Hello,
Re a 2002 1.8 Turbo: Should you be able to turn the radio on when the key is removed from the ignition?
Thanks
Old 01-14-2010, 10:27 PM
Radio should be off if the key is out of the ignition.
Old 01-14-2010, 11:04 PM
WheelyBug's Avatar
Northwest Corner of, TN, USA
Car: 2002 VW New Beetle Turbo S
my 02 Turbo S, after the key's out & the car's off, I can push my radio button & it works, for about an hour. I have the Monsoon radio/cassette player.
Old 01-15-2010, 01:21 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
AFAIK any radio (stock or aftermarket) will turn off when the key is removed. Stock radios can then be turned on again (without the key in) and will shut themselves off after approx 1hr.
Cheers
Simon
Old 01-15-2010, 08:18 PM
dmbluebeetle's Avatar
Blue Hunter
Riverside, OH, USA
Car: Blue '04 N. B. Turbo GLS
Originally Posted by rgar98 View Post
Hello,
Thanks
Yes, you should.......as stated, it will run for an hour and then will shut off. In my 2004 1.8 turbo the radio will play until a door is opened and then it shuts off.....after the key is removed.
Car beeping upon ignition? physh Questions, Issues, Concerns, or Problems with the New Beetle 7 01-05-2009 08:51 PM
Radio factory radio from new beetle 1998 and newer $70 turbobugger New Beetle Classifieds 1 08-06-2008 12:41 AM
ignition timming minivandan 2.0 Liter Gas 2 07-01-2007 01:44 PM
Fans on with ignition yellow1.8T Questions, Issues, Concerns, or Problems with the New Beetle 7 06-27-2006 04:19 AM
