The previous owner was nimrod - NewBeetle.org Forums
Old 03-23-2010, 03:35 AM
Default The previous owner was nimrod
Just bought a 2001 Beetle TDI.
The previous owner installed a DIN radio, but instead of buying a simple conversion harness, they snipped the orginal harness and spliced in a new harness.
Unfortunately the radio was stolen so now I have a bunch color coded wires deep in the stereo hole.
I am assuming the best thing to do is remobe the entire center dash area and get in there and just start splicing in a new harness.
Does anyone have a wiring diagram for the stereo plug? I am also assuming the speakers need to be wired back to a common ground.
Any other ideas??
I have a feeling this install is going to be murderous.
Old 03-23-2010, 04:16 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
if they're color coded to an aftermarket radio, all aftermarkets use the same wiring color scheme. shouldn't take too long.
Old 04-01-2010, 03:20 AM
umaxblaze's Avatar
Buffalo, MN, USA
Car: 2003 Turbo S
hey, i'm not sure if this is what you are looking for or if you are still having the problem, but i took this pic of the top of my factory head-unit. please note that my car has the monsoon stereo, so im not sure if the hook-ups are the same across the board.
Old 04-01-2010, 03:31 AM
Toad's Avatar
Hasa Diga Eebowai
Mableton, GA, USA
first the speakers are NOT a common ground. Also, all aftermarket radios don't support common ground, please don't do it, you will blow up the amp inside whatever you put into it.
also, if they cut the harness after the aftermarket splicing, the wires will be the same color as the new harness, if not, try this:
http://www.installdr.com/Harnesses/VW-Wiring.pdf
Do NOT connect all the wires to the aftermarket radio, you can cause a failure to the comfort control module or ecu. ONLY connect the 8 speaker leads, 12v battery + unswitched, 12V ignition switched, ground, and dimmer (if the aftermarket radio has a dimmer lead).
I hope this helps!
Come on try a little. Nothing is forever. There's got to be something better than in the middle...
Old 04-23-2010, 01:52 AM
go to the junk yard and cut out a new plud and attach them
new VW owner from Pa RUBZERK New Member Forum 5 05-18-2009 09:33 PM
Raff's previous cars raff Photos: Other Rides 27 12-30-2008 02:56 AM
*FORSALE 2000 beetle,1 previous owner,full vw service history* *strongy* Market Place Archives 3 01-30-2007 08:54 PM
Marks double yellow -previous famous owner tamerton1 Photos: New Beetles 8 07-12-2006 03:19 AM
More Previous Rides KNEWBUG Photos: Other Rides 0 09-26-2005 03:17 AM
