Please help with Satellite Antenna in a convertible. - NewBeetle.org Forums
Old 04-23-2010, 01:36 AM
Unhappy Please help with Satellite Antenna in a convertible.
Hi,I am new to the Beetle Forum and I look forward to being a contributor. I do need some help.
I am installing a Sirius Mobile Unit and I cannot figure out for the life of me how to get the Antenna from the outside of the car to the inside to plug into the unit.
I have a 2006 Convertible.
I saw that someone said they went through the dash and mounted it on the dash inside the car. I prefer to mount the antenna outside the car.
Can this be done? Is there a way to go through the firewall with some secret access?
If I have to mount it inside how do I take the top dash off?
Please help.
Thanks,
Steve
Old 04-23-2010, 01:56 AM
miffmole's Avatar
NBC Driver
SC, USA
Please help.
Thanks,
Steve
The Sirius instructions for convertibles have the antenna wire going to the back of the car, with the antenna attached to the trunk lid...
However, I just ran the wire, totally hidden, up the side of the dash, and placed the antenna on the left side of the dash. About 3 inches of wire shows at the antenna end. The reception is oustanding, and the antenna isn't at the mercy of the elements, other than the sun.
This took me about 3 minutes.
Old 04-23-2010, 02:14 AM
Thanks for the tip? Is there anyway you can take a picture of your setup and post it? Where do you have your Satellite receiver located?
Thanks,
Steve
Old 04-23-2010, 02:31 AM
miffmole's Avatar
NBC Driver
SC, USA
This picture was just shot in the dark, but you can get the idea...
Old 04-23-2010, 02:45 AM
Thumbs up
You have no idea how much you helped me! I have been going crazy trying to figure out what to do. By the time you took you picture I figured it out and completed the job.
I did not do exactly what you did. I went straight down the middle where the middle dash is. The head of the antenna sits perfect. There is even a little notch in the front of the dash it hide the larger part of the wire going into the antenna head.
I then tucked it into the middle dash all the way down under the crappy Flower Vase and straight into my mobile unit. Not one bit of the wire is exposed. I will take a picture in the morning and post it.
Thanks again for the help.
Steve
Old 04-23-2010, 02:50 AM
buckbeetle's Avatar
The Bug Noir
Alki Beach, Seattle, WA, USA
Car: 2005 Black NBC 1.8T
In the convertible it is better to run the Sirius antenna to the front of the car, or on the dash. Because of the rollover safety system in the back of the vert, there is another firewall type wall that makes it hard to run wiring to the back.
Additionally you can replace the center dash piece with the one that has the little bubble for the antenna.
buckbeetle
2005 NBC
2009 Acura TSX
2008 Ford Focus SEL
1998 Ford Explorer
salsa-man's Avatar
Bugaholic
San Antonio, TX, USA
Car: 2006 NBC Pkg 2
just fyi the factory satellite antenna is in the middle of the dash near the windshield.
Old 04-23-2010, 03:17 AM
miffmole's Avatar
NBC Driver
SC, USA
Steve
That's great! I'd be curious to see your setup when you take your photo.
Old 04-23-2010, 03:25 AM
miffmole's Avatar
NBC Driver
SC, USA
That's an idea...wonder how much that piece would be? Part number?
Old 04-23-2010, 04:58 AM
salsa-man's Avatar
Bugaholic
Car: 2006 NBC Pkg 2
We must have posted at the same time. I didn't see yours. But thats what I was talking about.
You can see some other pics of the antenna in a cabin filter how-to I posted here -> How To - Cabin Air Filter Replacement
The factory XM antenna uses the old style antenna with two connections and uses the square type connectors. Don't know if there is a different antenna for Sirius.
Old 04-23-2010, 12:52 PM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
I put my gps antenna under the center dash panel. It works great there and is invisible.
Old 04-27-2010, 12:02 AM
I just had a thought. Can a Sirius satellite adapter for an after market radio fit under the front dash?
Old 04-27-2010, 12:03 AM
What is the cabin filter used for? I had no idea it existed.
Old 04-27-2010, 12:27 AM
Here is how I set up my Satellite radio. The only wires that are showing are the ones going into the mobile unit. I could hide those better. I will this weekend.
Old 04-27-2010, 04:40 AM
miffmole's Avatar
NBC Driver
SC, USA
Where's your antenna wire hidden?
Old 04-30-2010, 05:54 PM
PeachyPeach's Avatar
Insert clever epithet
USA
Car: 2000 Silver Arrow GLS 2.0L 5 speed
They're also known as pollen filters. The air that comes out your vents goes through it first.
Old 11-16-2010, 11:07 PM
thebigtexan's Avatar
Oklahoma City, OK, USA
Car: 2002 GLS
Cool Use of Factory Sat Antenna
I recently purchased an '06 Convertible which has the factory XM. I also have the XM Skydock that I use with my iphone. Is it possible to use the original factory Sat antenna and connect to the skydock? I really like the skydock and have no need for 2 subscriptions.
Big Tex
Satellite Radio Antenna ghostRder1 Technical Modifications 8 06-30-2008 07:13 PM
NBC Satellite Antenna location Stargazer Car Audio 3 01-14-2008 08:30 PM
Anyone have satellite TV? silverspeedbuggy Miscellaneous Hoo-Ha Archive 22 09-20-2007 01:15 PM
Satellite Antenna ghostRder1 Car Audio 0 07-13-2006 03:31 AM
Satellite Radio pdoel Car Audio 56 01-30-2006 08:18 PM
