Anyone else have aftermarket head unit with rear USB pigtail? - NewBeetle.org Forums
Old 06-08-2010, 06:09 PM
PeachyPeach's Avatar
Insert clever epithet
USA
Car: 2000 Silver Arrow GLS 2.0L 5 speed
Default Anyone else have aftermarket head unit with rear USB pigtail?
How the heck do you mount the thing so it stays put?!
My Kenwood deck came with a separate plastic piece that holds the USB jack on 3 sides and has screw holes so you can panel mount it. I Dremel'd out a rectangular hole in the back of the glove box and screwed the piece down, and all was good for a few weeks. Then one day I was swapping flash drives and the !@?#$ cable pulled through the plastic piece and into the glove box. I shoved it back in and I think it's situated as it should be, but I imagine it'll happen again.
If anyone has dealt with this problem and fixed it permanently, I'd love to hear what you did. Thanks!
Old 06-09-2010, 02:30 AM
TN,
Car: 00 1.8T 5 speed, again lol
I've got one in my car. I just used a high quality velcro. It's weird velco. It's plastic and holds very well. Just make sure you clean both places that you're putting the adhesive very well, and velcro or 2 sided tape should hold it. If you use the 2 sided tape, I'd use the 3m trim tape. Hope this helps.
Old 06-27-2010, 06:56 PM
USA
It may come to tape and Velcro eventually, but the glove box was less of a pain to take out than I thought--I had the whole dash torn apart to run cables during the install, but it's only about 8 screws to remove just the glove box. I just put it back in like it was, and cable-tied around the plastic pocket (which had a notch that was probably meant for cable ties in the first place).
I found this cable online, which I may buy if it happens again or for a future install. They also have a 1/8" panel-mount extender for a stealthy rear-Aux.
USB Panel-Mount Type A Cable -- DataPro
Old 06-27-2010, 11:57 PM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
I just ran it into the armrest and plug in a flashdrive or ipod there.
New CD head unit? TODDREY Questions, Issues, Concerns, or Problems with the New Beetle 4 08-07-2006 02:22 AM
New CD head unit? TODDREY New Beetle Convertible 1 07-31-2006 01:48 PM
New CD head unit? TODDREY Car Audio 3 07-31-2006 05:18 AM
Aftermarket Head Unit With The Monsoon System teklein Car Audio 2 07-18-2006 07:07 PM
Aftermarket CD unit question redbug119 Car Audio 4 01-27-2006 09:08 PM
