Everything on the stereo has been fine, but while going over a speed bump my radio stopped putting out any sound.
Stereo is powered, and CD changer pumps out the jams, but the radio puts out nothing. I hit the "seek" or "scan" and it just rolls through the wavelengths - never stops, so I assume it is not getting a signal. The antenna is still on and tight; the antenna cable is still attached to the rear of the stereo. Unplugging the stereo to "reset" it didn't help. Any ideas? I searched quite a bit in the forums and found nothing like this. I did note some talked of a powered antenna, but would a 2000 GLX have such a thing? I didn't see a blue power cable... maybe a short in the antenna wire elsewhere? Or just a half-dead deck? |
The antenna on the roof attaches with threads, so I'm not sure what you mean by "plugged in". I went by a dealer and the fella said there was one more "attachment between the stereo and the antenna (he pointed at rear driver's-side pillar) but said I'd have to remove the headliner (w/special tools) to check it. Either that or the stereo itself has gone bad.
Takes about an hour to do |
Is your antenna bent? It should be straight out from the mast, i.e. like this / My 2000's antenna is bent over, there's a curve in the thicker part just above the mast and it's practically horizontal at the end, but I still have reception. It's not uncommon. I've heard of people with bent antennas having troubles, though.
If it is bent and you go to the trouble of taking out the head liner, that would be the time to test/replace it. |
| Tags |
| 2000 , dead , half , radio , stereo |
| 2000 Beetle Stereo Question??????? | giink | 2.0 Liter Gas | 9 | 12-08-2009 03:01 PM |
| Battery drain tied to fuse 42, non-mosson radio works fine | paultakeda | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 10-14-2008 01:35 PM |
| Radio works, no display | Alco251 | Car Audio | 0 | 07-08-2008 04:33 AM |
| stereo for a 2000 beetle | lgriffiths | Parts and Accessories | 4 | 11-13-2007 02:11 PM |
| Dead Stereo/CD Changer in 2000 Beetle | benchel | Car Audio | 1 | 11-07-2007 10:47 PM |
