The monsoon amps are located on the rear panel of the car where you flip the piece forward in order to access your spare. As far as putting an amp in, you can mount it anywhere you want but typically I see people mount them on the side of the trunk. Hope This helps a lil bit.
Hey Scott, I'm assuming you are going to use stock speakers and a stock radio (non-Monsoon). Right? Stock radios have a mini amplifier built in them, called deck power. They run from 5 watts per channel, to 50 watts per channel. Normally.
If it's a Monsoon unit, it will require the amp with it. Someone correct me if I'm wrong. ![]()
"Deutsche Stahl" |
Scott |
Scott |
Hi Scott,
I just changed out my old non-Monsoon radio/cassette with a brand new Monsoon unit I bought from ECS for about $38 + shipping. I also bought a set of Schwabben removal tools and the change out was uber-easy. I then took the car to Dirrito Bros. VW in Walnut Creek and their service guy Ricky put the code into the unit to take it out of safe mode. Thanks Ricky! The unit looks and sounds great (output is identical in terms of volume as the o.e.m. H.U. ) despite the fact that virtually every post here and elsewhere said it would not work. Sometimes you gotta go with your gut, and mine told me this would work and it does. Good luck with your swap!
Kevmo-n-Lil'Red
| TT dash swap. | vdub11 | Styling Modifications | 24 | 08-10-2010 12:00 AM |
| swap? or not? | masteramd09 | Technical Modifications | 3 | 01-31-2010 11:06 AM |
| FS: Caractere parts, factory radios, TDi parts... | beetlecupkid | Parts and Accessories | 63 | 10-25-2009 02:33 AM |
| WTB: Stock Radios W/ or W/O Code | FallinApartBoy | Market Place Archives | 16 | 07-30-2007 07:15 AM |
| 1.8t swap ????'s | gtpon22s | 1.8 Liter Turbo | 0 | 02-28-2007 11:08 PM |
