"No Changer" - 03 Turbo - NewBeetle.org Forums
Old 08-02-2010, 06:52 PM
ghostchild's Avatar
nOOb
georgetown, KY, USA
Car: 2003 red turbo
Default "No Changer" - 03 Turbo
The factory audio system and 6-disc changer are still in the car. Radio works just fine but when you try to flip over to listen to CD's, the dash display says "no changer." CD's will insert and eject just fine, but won't play.
The battery went kaput shortly after this problem appeared. Battery has been replaced, and still no luck. Anybody know how to get that changer reset?
Old 08-02-2010, 07:12 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Use a pin to insert in the reset hole
Or check the wiring to the changer, is it in the boot or under the armrest ?
Old 08-02-2010, 07:29 PM
ghostchild's Avatar
nOOb
georgetown, KY, USA
Car: 2003 red turbo
In the armrest. I've not really tried yet, but off the top of my head I have no idea how to remove it to check the wiring. Where is there a reset hole? I know exactly what you mean, just don't know where to find it.
Do you refer to your bug as "he" "she" or "it" when talking about him/her? Beetlescott The New Beetle Experience 33 11-22-2010 08:55 AM
