Radio will not go in safe mode - NewBeetle.org Forums
Old 10-24-2010, 05:45 PM
Black zippy bug
Sand Lake, MI, USA
Car: 99 black 2L, 2001TDI Jetta, 2006 TDI jetta 2010 TDI Jetta wagon
Default Radio will not go in safe mode
99 bug gas,
I have unhook the battery for 1/2 hr, pulled the fuse, and it still will not go in safe mode. when power up it is at 88.3 fm and no sound, can not adjust anything, will not run tape or CD or AM band
Old 10-24-2010, 06:20 PM
Why do you want it to go into safe mode? I find normally if the car is unaware that the headunit has been disconnected it won't go into safe mode. The only way you can induce safe mode in my experience is to unplug the radio with the car battery connected so the car is aware what's going on. Plug it back in and it should ask for the radio code.
Old 11-02-2010, 03:47 AM
My battery went dead today. Jump started it and my radio is doing the same thing. I know how to reset it if it goes into safe mode problem is it didn't. Radio displays 88.9, won't play, can't change station, can't change mode. Thermometer isn't working either. Everything else is fine.
Anyone have any suggestions?
Old 11-02-2010, 03:54 AM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
Im confused, which is it, it wont come out of lock, or your trying to lock it?
Old 11-04-2010, 09:05 PM
QQQ's Avatar
QQQRegistered Member QQQ is offline
Fairfax, VA, USA
Car: Y2K GLS TDI
Weird that its in a zombie state, neither dead (safe mode) or alive (operational). Maybe you can feed it some brain.
Dyslexic people untie!
Radio Safe Mode rob11g Questions, Issues, Concerns, or Problems with the New Beetle 4 01-09-2011 04:41 PM
Hi i replace my car battery and my radio turn in safe mode ismael.memo@yahoo.com 2.0 Liter Gas 4 02-23-2010 04:41 AM
Radio in Safe mode! Help LPC Questions, Issues, Concerns, or Problems with the New Beetle 10 05-16-2007 04:21 PM
Safe Mode Stereo !!! Help icy7690 Questions, Issues, Concerns, or Problems with the New Beetle 4 05-08-2007 05:18 AM
98 beetle radio displays 2 safe mode help gerry Car Audio 0 02-15-2007 06:51 PM
