Me likes it! Excellent job!
My little cubby/change pocket filler is going to be different than yours, because it is just an "open void" down into that area. I'm also betting that since my armrest slides forward for better postioning in use, that is why the lock and hence, catch, was deleted! MORAV
Will your harness get me from the console to the trunk (long enough for good hidden routing)? Be way easier than routing from the head unit! I can splice in the wires at the console harness if necessary. MORAV |
As far as the CD changer in the trunk, THANK YOU! I thought it was just me with the designs complaints. Not only that but CD changers capable of playing MP3 and WAV files have been available for a while, and yet these only play regular CD's and valued at $600+? I am not complaining, I mean I only paid $39 for mine but it makes no sense to not have a trunk mounted one. Except for when you have to take the spare tire in and out. I can see some ppl destroying it ![]() |
Btw my '05 has an MP3 factory jack. I think those head units you are talking about do also, the jack is just remote, like mine. And the head unit reads the MP3, selects, everything, but I know **** about MP3s. lmao Postscript: I don't like the potential exposure to the elements, and I like the use of cartridges, where I can pre-load several for a trip and not deal with cd cases or loose cds. I know MP3!!!! MORAV Last edited by MyOtherRidesAVette; 12-23-2010 at 06:05 PM.. |
I only mention this because you say you don't know much about mp3 Unfortunately mine does not have the aux jack like yours does, so for now I am happy with the changer, later down the road I will look for a donor car with the above mentioned. I have all my music backed in my computer, if a disc gets scratched it costs me a few cents to replace, BUT, the rear mounted with the magazines is a lot easier to load and unload as you mention. I only bought this because of the price. I also thought about the elements, dust more than anything else. |
P.S. - Anybody gonna want a "new" 6cd console unit in about a month, for $40 shipped? In original packaging. MORAV |
The harness I have is just over 6' in length, radio end has 9 leads out and the CD connector has 11 here is the direct link to it on ECS Volkswagen New Beetle 2.0 > Search > Cd Changer > ES#337166 CD Changer Wiring Harness - 3B0051592B |
The cd changer uses 10 active pins in the male side of the connection. When you get a chance can you look an see if two of the eleven are common to one pin. Ditto the other end, how many active pins? If it's not active the will be no metal connector in the plastic plug. Sounds like the have some "trick" wiring in the run of the harness like GM. Probably going to be easiest to just clip off the plug in the console, extend the wires to the trunk, and reconnect the plug.
MORAV |
OK, I just put this one and my hands are still recovering. I have the plugs all connected and the top is working, but it seems as there is no power to the changer. I disconnected it and tried again but to no avail. Any ideas? I saw there were two fuses for the radio and both of those seem ok. This is an 04 Convertible. The radio is the standard cassette with the CD changer controls.
Thanks |
This may be a stupid question when the new ones are $39 but is yours new, or did you buy it of someone used? You may need to get a meter or test light and make sure the harness is hot. Power to operate it does not come from the radio head. T4L is going to have to look in his Bentley and see where the power is fused.
M. |
Yes, I have one that I just received from ECS. Yes, if you can find out what pins or fuse I should check that would be helpful. When you first turn on the car, should you see any light on the changer? I don't see anything. Thanks for the help.
This is a guess, but an educated one (doesn't always work with VW engineering though), the changer should power up through the use of a relay controlled by the radio head unit. In other words the head unit, "requesting" the cd changer, turns the changer on. I haven't installed mine, because I think I'm going to do the trunk mount instead, for both security and the ability to use multiple magazines. T$L has installed his, and should be able to answer you question, and whether or not the unit's power is controlled by the HU.
M. |
Here is the p/n for the little "cubby" (storage compartment, change holder) that fills the small space below the Changer, in the console, along with an online source if you don't want to do the Dealer thing.
VW P/N ICO-857-058B-33N Volkswagen Beetle Center Console Storage Unit at Dealerfit.com M. |
Just an update, I was finally able to coble together a partially working cable and VAG-COM to read the radio codes, my came as default 06031 which means no changer installed, I changed it to 06033 which should be changer installed, but then nothing worked any different. The radio still said no changer when I pushed the button. The manual seems to indicate pulling out the radio to install the harness, but the harness is already installed, so maybe the cable isn't connected to the back of the radio? Without another Beetle or changer to test, I can only guess that my changer is non-functional
.pdf file only showing first page, need to investigate and may need to rescan into a new file, I'll get back to you. M. |
Does anyone have the storage tray they'd like to sell who has done this conversion?
| Rear power point door won't close in newer style console? DIY Fix! | MyOtherRidesAVette | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 12-18-2010 12:38 PM |
| console cd changer | TampaDub | Parts and Accessories | 2 | 03-01-2010 03:36 PM |
| DIY: Install an armrest in your NB | zeusenergy | Technical How-To | 3 | 08-14-2008 02:11 PM |
| MBC DIY install | TurboS-CR | 1.8 Liter Turbo | 19 | 06-03-2008 03:31 AM |
| Center console cd changer | skachic20 | Car Audio | 6 | 07-28-2006 12:19 AM |
