Metra wiring adapter on 2001 monsoon - NewBeetle.org Forums
Old 12-27-2010, 03:16 AM
Default Metra wiring adapter on 2001 monsoon
Just pulled the factory monsoon to check out the wiring for after market stereo installation. I noticed the metra adapter as well as the factory monsoon only have speaker inputs for the front speakers. The gray and white wires. That does not compute to me. So I just wire up the fronts and have no fader control with the head unit? The monsoon amp must divy up the fader?
Also the red metra adapter that has the blue antenna turn on lead as well as amp leads plugs into the blank side (yellow) of the blue green and yellow factory connector where as the only side of that connector that has wires going to it are on the blue side, cd change from what I have read on the forum.
Thanks for your help, I know someone has to know the answers!
Old 12-29-2010, 08:39 PM
dmbluebeetle's Avatar
Blue Hunter
Riverside, OH, USA
Car: Blue '04 N. B. Turbo GLS
The OEM radio uses it's own fade & Balance controls to move the sound around the car, all the Monsoon Amp does is enhance the sound with additional speakers.
All OEM radios are 4 channel output whether there is an amp in the vehicle or not.
2001 with Monsoon whitey0375 Car Audio 10 08-23-2010 12:16 AM
Wiring/Electrical question for iPod adapter to factory HU Storm Shadow Car Audio 7 03-13-2010 12:19 PM
FS: Metra dash kit 98-00 and antenna adapter Woz2000 Parts and Accessories 1 01-09-2009 09:22 PM
Wiring difference between pre and post 2005 Monsoon? WhtNrdy Car Audio 7 07-16-2008 07:30 PM
2001 NB GLX Headlight Wiring Modification IHATESPAMIAM 1.8 Liter Turbo 0 10-15-2005 11:45 PM
